V18 cut out |
Amplighting&sound
Registered User Joined: 31 July 2011 Location: Essex Status: Offline Points: 359 |
Posted: 27 June 2012 at 8:26pm |
Can any one help i need to make the cut out in my 1850s bigger for the v18 as its bout 5mm to small any help would be lovely
hmaudio
Old Croc Joined: 03 April 2009 Location: Nottingham Status: Offline Points: 3844 |
on the pdf i have for the v18-1000 it says rear mounted is 425mm and front mounted is 430mm
hope this helps cheers Adam
This account is used by 2 people. |
Amplighting&sound
Thank u m8 but i hav that info its just the cut out needs to be bigger but how do u get a routa in to do it please help lol
hmaudio
if the cab is already built its going to be hard to make the cut out bigger.
Amplighting&sound
True dem cab is allready made would it hurt if cut out was 5mm to small would this make cone rub
Amplighting&sound
Any 1 got any input
Vert
Registered User Joined: 30 March 2011 Location: Leicester Status: Offline Points: 396 |
and a Rotary rasp + alot of patience |
Box builder, pm for quote
Amplighting&sound
Do well thank u
Amplighting&sound
Hello again just tryed the rasp and its a very slow process does any one hav any other ideas please
infrasound
If it's only 5mm you should be able to use a chamfer bit on a router.
Set it so that the bearing just about catches the inside wood.
infrasound
Like so
Amplighting&sound
Thank u infa but my prob is i can only gt my trimer round the bottom half of cut out as the chamber gts narrow at the back ?
