1850 loaded with void |
WILLIAM12345
Registered User Joined: 02 May 2012 Status: Offline Points: 39 |
Posted: 17 July 2012 at 12:41am |
i soldered my speakons but someone said after a while they will over heat and fall apart. an that i should use spade clips . is this true?
imageoven
No.
Every thing breaks eventualy (entropy etc.) but it won't be from it 'heating up'. As long as the wire you use is of a decent thickness it won't even get warm. |
maxwell92
Registered User Joined: 07 December 2009 Location: MCR/Sheffield Status: Offline Points: 270 |
Solder is probably more reliable, I can imagine spade clips vibrating off before soldering falls apart
ClackS02
Registered User Joined: 12 March 2013 Location: United Kingdom Status: Offline Points: 33 |
Not exactly on topic, but it relates:
When making 300+ amp connections in the car using 0 or 00 gauge wiring, it is suggested to crimp rather than solder (as solder never makes 100% connection) something about air bubbles.... anyway... for speaker wiring, soldering is ideal!! how do you think the speakons/jacks are mounted to the amp main circuit board? Its quite a bit of heat to melt solder, so if its getting that hot... RUN AWAY :) As long as your good at soldering, and there are no 'Dry Connections' you'll be fine mate :)
