Behringer inuke NU6000 vs KAM KXD7200 bench tested |
Post Reply | Page <1 89101112> |
bmholbro
Registered User Joined: 28 October 2014 Location: Fort Worth, TX Status: Offline Points: 30 |
I'm not sure what the benefit would be in the NU-4 6000 unit versus the regular unit since it essentially is the other in bridged form.
As far as the Berry not being pro gear... it definitely isn't comparable to the more costly options out there. I picked up mine mostly because I was looking for an inexpensive short-term solution to drive a pair of budget dual 18s. I use it for my own house/techno parties at mid sized clubs and warehouses a half dozen times a year. After a few events using it I decided I could live with the amp long term. I picked up a 2nd unit primarily because by brand I don't fully trust it and occasionally I rent another pair of subs so having it saves me some rental $s. For what we use them for the subs do what they are supposed to do... they sound fine. The DSP feature is nice for added convenience if I am setting the subs up alone in a venue and not with the rest of my system since I don't have to use by drive rack. I'm not going to go start a rental company with these things, but for our usage and the subs I have they do fine. |
osse
Registered User Joined: 26 August 2013 Location: Sverige Status: Offline Points: 84 |
Has anyone tried one of these amps on a true sine generator, for example one of these Kipor sinemaster 2600 generators and would it work?
http://www.poweredbykipor.com/pdf/owner/IG1000-IG2000-IG2600-CARB-OwnersManual.pdf I've had a Peavey IPR 1600 which was destroyed on a generator(not that model I think) and it would be sad if the same thing happened with an iNuke.
Dennis Speijer
New Member Joined: 05 September 2015 Location: Netherlands Status: Offline Points: 4 |
Dear Teslaman,
I am looking for a circuit diagram of the Behringer NU6000 Amp. Do you know where i can find it? Kind regards, Dennis |
all bass
Behringer doesn't hand out any circuit diagrams as far as i know. Is the 3 year warrant period already over? |
Dennis Speijer
I am not sure. The guy i am repairing it for should know. I'll ask him, but i don't think so otherwise he wouldn't have asked me. I replaced a component already but it keeps staying in it's protective mode, so i have to dig deeper. That's why i thought i'd ask anyone on this forum.
Dennis |
byradzio
New Member Joined: 16 September 2015 Status: Offline Points: 3 |
Hi,
Could somebody write what is writen on IC4 and C45? And make good resolution photo of whole PCB and send to email mailto:byradzio2+replay@gmail.com - byradzio2+replay@gmail.com ? it`s over here:
Edited by byradzio - 16 September 2015 at 3:30pm |
simonp1100
Hi, Components values below are from a INUKE 3000 diagram and i assume they are the same on the 6000 ?????. Hope this helps
IC4 = VIPER22. C45 = 1000UF 6.3 Volts. |
Dennis Speijer
Hi Byradzio,
I made a pic of IC4 for you but i cannot post it on this forum. Beats me why but it says: VIPer22A 413119 regards, Dennis |
Dennis Speijer
Hi Byradzio,
The capacitor is a 103j400 type. I searched on the internet and i believe it says: 0.01uF 200V/AC 400V/DC. Regards Dennis |
byradzio
Could you sens pics to mail please, byradzio2@gmail.com |
byradzio
Thank you very much, too all of you for your help :-D
foler
Registered User Joined: 08 April 2011 Location: HR Status: Offline Points: 103 |
1.16kW into 8 Ohms, 1.80kW into 4 Ohms for Bass duty
Is this mean that this amp deliver 3.6kW in bridge mode/8 ohm all day long? ufff, maybe I make stupid question because this amp is not bridgable? But someone write that this can be done via remote connect software? Hi Jason,
What wiki are you talking about? The only one that I know of is the X32 Wiki. I just checked and no one has registered there awaiting approval. Regarding your initial question, I did some digging and this amp can be configured in bridge mode. You need to use the iNuke Remote Connect app to change the amp to that mode. According to the manual (page 7), when in bridge mode both outputs are identical. In other words you would simply have to connect your sub to one of the speakon jacks. Wiring would be the 1+ and 1- for either jack. I'm sorry you wasted a lot of time. But it only took me about 10 minutes to download the app, change it to bridge mode, look at the graphical path, and read the manual. Paul Edited by foler - 08 July 2016 at 12:28pm |
