  New Posts New Posts RSS Feed - A Compression Driver Flat From 10 kHz - 20 kHz
 Post Reply Post Reply Page  123 8>
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Topic: A Compression Driver Flat From 10 kHz - 20 kHz
    Posted: 25 July 2012 at 7:50pm
Possibly I am overlooking a particular brand or model, as it seems most difficult to find a compression driver that is flat from 10 kHz - 20 kHz.
Has anyone stumbled upon one?
Best Regards,
ovidias View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ovidias Quote  Post ReplyReply Direct Link To This Post Posted: 25 July 2012 at 8:25pm
JBL Selenium D220
http://www.jblselenium.com.br/marcas/produtossub.php?idLinha=40
Edited by ovidias - 25 July 2012 at 8:25pm
rish View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rish Quote  Post ReplyReply Direct Link To This Post Posted: 25 July 2012 at 8:26pm
Hi Elliot.I use the faital pro 1" comp drivers and its one of the smoothest  i ever heard.
Rish
MattStolton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattStolton Quote  Post ReplyReply Direct Link To This Post Posted: 25 July 2012 at 8:27pm
The Beyma Ribbon?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 25 July 2012 at 8:33pm
Flat enough?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 25 July 2012 at 9:05pm
By flat, I mean a deviation no greater than +/-2 dB from 10 kHz – 20 kHz. Achieving a flat response from 10 kHz below is not hard to accomplish from a compression driver.
The Selenium D 220 TI: – 10 dB @ 21 kHz
The Beyma TPL 150: - 4dB @ 20 kHz
The Faital Pro ???: Model Number
The graph Marjan posted is around –6 dB @ 20 kHz (from 10 kHz – 20 kHz)
I am surprise to see so many compression drivers declining above 10 kHz.
Best Regards,
Edited by Elliot Thompson - 25 July 2012 at 9:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 25 July 2012 at 9:58pm
They all do that Elliot. You need to compensate that with your passive xover to boost the hf.
TONY.A.S.S. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 25 July 2012 at 10:05pm
I also think that a test should be taken to establish how far up the scale you can actually hear. It would be a shame to finally find something and realize that it was a pointless exercise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattStolton Quote  Post ReplyReply Direct Link To This Post Posted: 25 July 2012 at 10:25pm
Perhaps I don't get out enough, but at my ripe old age, my hearing is only rolling off at 16KHz!!!
Do I get a medal?
MessyM2k8 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MessyM2k8 Quote  Post ReplyReply Direct Link To This Post Posted: 25 July 2012 at 10:28pm
I did this test a couple of days ago using a signal generator and a JBL active speaker. I found i could hear easily upto 18kHz.
Muckerbarnes1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Muckerbarnes1 Quote  Post ReplyReply Direct Link To This Post Posted: 25 July 2012 at 10:50pm
Elliot could you establish a point to this exercise. Some are as we know awful. Some are great, and a tad of EQ is even better.
Billy Dawg.
infrasound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote infrasound Quote  Post ReplyReply Direct Link To This Post Posted: 25 July 2012 at 10:55pm
Beyma CP21/22
Okay, it's not a compression driver per say. But it is ±2.5dB 10kHz-20kHz.
Edited by infrasound - 25 July 2012 at 11:02pm
