Martin error code FTER |
AM55
Joined: 16 August 2007 Location: Matlock Status: Offline Points: 1725 |
Topic: Martin error code FTERPosted: 21 September 2012 at 11:19pm |
Anyone have any idea what this is? I have it on a few Roboscan 918 fixtures, doesn't seem to be listed in the 918 or mac 500 manual. Thanks for your time. |
kedwardsleisure
Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 5157 |
Posted: 22 September 2012 at 1:07am |
FTER means it thinks the internal temperature is too high.
North Staffordshire |
AM55
Posted: 22 September 2012 at 7:14am |
That is strange as it is doing it from start up when they are cold. Where is the sensor that deals with this?
The lamp compartment/exhaust does get really hot which worries me sometimes. When I brought them nearly all the heat reflectors had melted into the fans which was nice. Edited by AM55 - 24 September 2012 at 12:30pm |
steviec_lj
Joined: 06 September 2012 Location: Scunthorpe Status: Offline Points: 69 |
Posted: 24 September 2012 at 5:45pm |
If they're doing it from start up, or cold, then the sensor is giving a false reading or short circuit. This then needs to be replaced.
A good clean also helps, along with maintenance. |
AM55
Posted: 24 September 2012 at 6:22pm |
They have all been recently cleaned. Do you know where the sensor is located and if I can get it off RS?
kedwardsleisure
Thanks(1)
Posted: 02 November 2012 at 12:06am |
The temp sensor will be the NTC on PL303. If it's faulty it may cause the fan to ramp up to full speed. You should be able to interrogate the measured temperature in the menu?
AM55
Posted: 02 November 2012 at 8:56am |
Thanks for the info!
kedwardsleisure
Posted: 04 November 2012 at 8:08pm |
when I said NTC it may be a PTC as well, dont hold me to it!
