  New Posts New Posts RSS Feed - Mc2
Mc2
dj scratchy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj scratchy Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2012 at 9:59pm
Originally posted by JohnnyPyro JohnnyPyro wrote:
MC range doesnt have the power for bass? LOL you have obviously never bridged an MC1250!
I'd say the E series is better sounding than the T series, but not much in it, if you want absolute quality then get some MC's and i will qite firmly stand by this statement, they are the best sound pro audio amp you will ever hear!
is the mc 1250 the 3u one i did foolishly say weight is no issue but im not goin to lie i would really like to avoid carting 6 u of amp when i can get 2 u to do the same job there is also the price i want to build 2 of the same rack
sound, light, trilite, stage decks, complete stage packages indoor and outdoor 07568188104 sl systems sound&light
JohnnyPyro View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnnyPyro Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2012 at 10:19pm
Yes its the 3u jobbie, it is a lump of an amp, thats the major downside, flawless sounding amp, im in the process of moving over to E series, but i'll be keeping some of the MC's for home use as they are that good
Powered by MC2 & XTA
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj scratchy Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2012 at 10:35pm
e series is were i want to be but it wont happen right now i have a pl236 and a bunch of 2450's to sell and the chance to have 2 mc650s and work them off so got a good start on the mc range but the way i want to do it i think im goin to have to get another brand for bass even the t3500 wont do as it wont do 2 ohms so on bass its e45 or other cheaper alternatives till im rich any sugestions on bass amps ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnnyPyro Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2012 at 10:47pm
personally i would avoid running subs 2ohm , as soon as you start running that low you affect the damping factor , id stick with 2 ohm stable amps but only go 4ohm per ch , i would go for 2 e45's or an e100
Edited by JohnnyPyro - 25 October 2012 at 10:48pm
Tobie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tobie Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2012 at 5:42pm
Matrix too is another opition aparently not far of an Mc2 E Series but a tad cheaper
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj scratchy Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2012 at 10:49pm
would it really make that bigger difference id be running 4 tsw721's per channel an e45 should handle that no problem surely
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2012 at 11:24pm
Im assuming TSW721 is loaded with something similar to 2150?
What's your music type?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnnyPyro Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2012 at 11:24pm
It will run them fine, i just preffer not to take amps down to 2ohm
dmx256 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dmx256 Quote  Post ReplyReply Direct Link To This Post Posted: 27 October 2012 at 6:59pm
i run all mc2 t series amps and they are great, and i too would never ever run an amp into 2 ohms on bass
Logic System XTA EAW MC2 Robe Anytronics Futurelight Trilite Tas and a wife....
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 27 October 2012 at 7:12pm
Anyone here ever run 2x PD2150s per channel, dnb/Roots reggae, on mc2/FFA,  with HPF = 30-38hz?
Seen someone try this with MA5000VZ on 32A, and it failed badly.
Edited by levyte357- - 27 October 2012 at 7:15pm
Tweeter_Box View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tweeter_Box Quote  Post ReplyReply Direct Link To This Post Posted: 27 October 2012 at 8:54pm
i own a mc2 t series amp, only good for mids or tops imo!
B.P.Sound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B.P.Sound Quote  Post ReplyReply Direct Link To This Post Posted: 28 October 2012 at 7:39am
Hi there I have a great T2000 and a blown up T1500 £500 for both. The 1500 needs some TLC on the circuit board and patients.
T2000
T1500
http://www.londoneventrentals.co.uk/ https://www.facebook.com/LondonEventRentals
