Fane 400W 18" |
Post Reply | Page <1234> |
Goodvibetribe
Young Croc Joined: 06 December 2011 Location: Cardiff Status: Offline Points: 959 |
Lev, Would you say its worth me just building superscoops then to replace these, rather than hunting for the plans to build more: http://forum.speakerplans.com/scoop-id-needed-please_topic74382.html If thats the case then im also after another pair of 18B400 im getting the impression they seem to be quite sought after still, I Certainly dont have complaints with mine. (sorry to crash your thread with this question Scott)
levyte357-
Would suggest you search around for used Supers, before building.
They work splendidly with many Fane drivers. |
SBC
Registered User Joined: 25 November 2010 Status: Offline Points: 1266 |
the old fane studio 18 is probably one of the best drivers that have ever graced the scoopists.
F.T.S.S.
levyte357-
Yep, parameters typify quintessential scoop driver. If only Fane could have given it, Xmax=12mm, BL=32, 800W Power handling, without changing anything else.. |
onefootskenk77
Young Croc Joined: 11 October 2008 Location: Herts/Zimbabwe Status: Offline Points: 677 |
Have 300 watt old fane in scoop 😍😜
EMPIRE SOUND
mykey-
Old Croc Joined: 03 March 2010 Location: ID/UK Status: Offline Points: 6114 |
Best SOUNDING scoop driver bar none
Best scoop design for this is the Fane 15'' scoop scaled up by multiplying all the measurements by 1.2. Keep the width down to 24'' 610mm wide though ........how does he know this members might ask.......ANSWER: I used to own 16 of them : ) |
scott_fury
Registered User Joined: 28 October 2012 Location: Bristol Status: Offline Points: 319 |
That's a pretty solid endorsement!
Sinai Sound
I heard 3 in scoops on the end of a JTS pre & JTS 6k amp combo
Surprised with how good it sounded!
soundchippy
Young Croc Joined: 09 September 2011 Location: Tavistock Status: Offline Points: 770 |
in the beginning we had a superscoop with one of those fane 400's. did the business for years and sounded good doing it!
scott_fury
That's the internal width, not including the thickness of the sides? The 15" Fane scoop has an internal width of 565mm, which x 1.2 gives 678mm. It's this that should be reduced to 610mm? |
mykey-
mykey-
