MT-130 doubt |
superspunk
Registered User Joined: 16 November 2012 Location: Spain Status: Offline Points: 60 |
Posted: 17 December 2012 at 5:04pm |
Anybody knows the dimension of D??
JR.junior
71-(4x1,8)
superspunk
I dont understand your answer... (4x1,8??)
JR.junior
Edited by JR.junior - 17 December 2012 at 5:34pm |
JR.junior
1.) 1,8cm thickness of panel. (chipboard, mdf): 71,7-7,2=64,5cm
2.) 1,9cm thickness of panel (ply): 71,7-7,6=64,1cm |
mini-mad
should the baffle not be 30mm ofset from being flush with the front of the cab?
superspunk
Another way for the question...
D1 and D2 ??
JR.junior
whatever!
superspunk
Ok, so you suppose that x = 2 x 1,8.. Why?
kevinmcdonough
hey
The short answer is that it doesn't matter. Compression drivers, being sealed drivers by default, dont need to worry about the size of the chamber they are in, they dont need any particuluar volume to work. So you can set the baffle that the horn screws into wherever you want really. As people have said you'll probably want it back 30 or 40mm from the front so that you can get a grill on if you plan to use one, but other than that you can decide yourself. k |
JR.junior
mini-mad
looks good to me.... being 2x18mm should make leveling out the baffle much easier |
