  New Posts New Posts RSS Feed - Turbosound plan
Turbosound plan
AcidAda View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AcidAda Quote  Post ReplyReply Direct Link To This Post Topic: Turbosound plan
    Posted: 03 December 2006 at 1:53pm
hi all,
I am looking for plans of speakers you can see on the picture below. Above all the horn, but the mid top would be good also.:) I think it is older model of TURBOSOUND speakers (I didn't find it at turbosound web site).  I have gone through the forum, but without effect.
Is in horn 18" speaker inside. Is it the same construction like ES-18BPH?
I would like make by twos pieces horns per side.
Ada
Nigey-C View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nigey-C Quote  Post ReplyReply Direct Link To This Post Posted: 03 December 2006 at 4:09pm
bass cabs look alot like the ASS BS600
can be found @ http://www.assspeakers.com
you can also find some tops that look a lot like the ones in your pic.
specialjustin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote specialjustin Quote  Post ReplyReply Direct Link To This Post Posted: 03 December 2006 at 4:32pm
If there are bs600's, then the internal costruction is not like the  ES-18BPH
Post Options Post Options   Thanks (0) Thanks(0)   Quote AcidAda Quote  Post ReplyReply Direct Link To This Post Posted: 04 December 2006 at 4:52am
Thanks for quick reply guys.
It realy looks like BS600 and how in this topic man writes, THEY DESIGNED AND BUILT GEAR 4 TURBOSOUND.
In this case, have anybody plan for BS600?
I think that in ES-18BPH is the driver turned conversely, have I right?
gingerbiscuit69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gingerbiscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 09 December 2006 at 8:53am
theres better designs out there!.... they are well old!
Richard Hart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richard Hart Quote  Post ReplyReply Direct Link To This Post Posted: 11 December 2006 at 11:20am
Has technology moved on that much?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gingerbiscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 12 December 2006 at 7:39am
horn technology hasnt really, but driver have, so inding a design tuned for a modern driver with higher power rating and efficiency will make more bang for your watt!
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2015 at 11:53am
This is a funny topic!
To me it just looks like the tse system, 8 pcs tse-111 & 8 pcs tse-118
Just googling around for old turbo threads...
shagnasty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2015 at 11:57am
Spot on, that's exactly what it is, and there a VERY few designs that touch a TSE-x18 to this day as the 18" plays upto 250Hz, clean....
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2015 at 12:04pm
Funky drive unit, small VC & MMS, springy, poke it and it jumps, tap it & it says yeah!
Not like most heavy 18" cones.
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2015 at 12:13pm
not easy to find the old drivers any more though sadly.
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2015 at 12:32pm
Equals are still made & sold:
Funktion one has something equal, f118 / 218 claims response +-3dB up to 280 hz:
http://www.funktion-one.com/products/f118-mk2/
But operating band is set up to 200hz
Tsw-718 claims response +-4dB to 250 hz
