  New Posts New Posts RSS Feed - P-Audio SN 15MB Dis-continued!
reessi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote reessi Quote  Post ReplyReply Direct Link To This Post Posted: 11 April 2013 at 10:35am
Thanks for your reply, I have compared the parameters and the P-Audio 15BM-300B 15" 300W would seam to be the closest match but the paramaters are not exactly the same, but I do not understand how to use the parameters to calculate if the box will work for the newer model? Do you think it will work ok without modificaton. I understand that there is an optimum air volume you want inside and the port length size is important!
P-Audio SN 15MB 300w old model:
Thiele-Small Parameters
Resonant Fequency (fs) 47 Hz
Impedance (Re) 5.5 ohms
Coil Inductance (le) 0.85
Electromagnetic Q (Qes) 0.31
Mechanical Q (Qms) 8.31
Total Q (Qts) 0.30
Compliance Eqiv. Volume 176 liters
Mechanical Compliance of Suspension (Cms) 151 uM/N
BL Product (BL) 19.70 T-M
Diaphragm Mass incl. Airload (Mms) 75.7 grams
Equivalent Resistance of Mech. Suspension Loss (Rms) N/A
Efficiency Bandwidth Product (EBP) 151
Voice Coil Overhang (Xmax) 3.5mm
Surface Area of Cone (Sd) 907cm2
P-Audio 15BM-300B 15" 300W New model:
Re.....................................................................................5.7
Fs...................................................................................48hz
Mms................................................................92.19 grams
Mmd................................................................77.81
Qms..................................................................................5.39
Qes...................................................................................0.43
Qts....................................................................................0.40
Vas..................................................................123.35l
BI...............................................................................19.19
Cms.......................................................................1.2e-04 m/n
Rms.........................................................................5.10 ns/m
Le (at 1kHz)................................................................0.44 mh
Many thanks - Simon.
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 11 April 2013 at 11:01am
winisd pro is the (free) software you want.
don't get hung up on the wattage.. it's not an important specification really.
teeth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Posted: 20 October 2022 at 8:44am
where did you get to reesi?
i'd be interested in any recommendations of drivers for the X15 - the SN15MB is long long gone now, and p audio kit is hard to get hold of in the UK atm
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 20 October 2022 at 8:55am
did you not get a driver?
i replaced some sn15mb in some xm15s with bms 15n620 for a while... they are good. think people also used to say eminence kappalite were also appropriate replacements
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Posted: 21 October 2022 at 8:55am
i did get one aye but it's in germany :(
also aware that if anything happens there's no way to recone it seems...
i'll look in to the kappalite - thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 21 October 2022 at 9:36am
Oh no - did it get stuck there?  Confused
What are you going to do?
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Posted: 22 October 2022 at 3:58pm
i got spooked bringing it back on the plane, figured airport security might not be kind about a large magnet... didn't want to risk losing it.
hopefully a friend will be driving over before the year is out!
thanks for sending it earplug :)
in the mean time i guess i'll start poking about with drivers for the X15, good exploration time to be had perhaps.
nice springy neos being first port of call
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 22 October 2022 at 4:13pm
Aaah ok - as long as you do find a use for it. It is a good driver.  Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Posted: 24 October 2022 at 9:49am
any opinion on the 18sound 15ND930 for this use, folks?
This page was generated in 3.047 seconds.
