  New Posts New Posts RSS Feed - what is best driver for 1850 horn
Soluation audio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Soluation audio Quote  Post ReplyReply Direct Link To This Post Topic: what is best driver for 1850 horn
    Posted: 20 May 2013 at 11:14am
new to this game and finding this site great for info.
im building 2 1850 horn bins and wondering what the best driver is for a really low frequency result, also trying to build these bins on a wee bit of a budget in mind, thanks for the help
Laurin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Laurin Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2013 at 12:00pm
1850 are not capable of very low frequencies.
You need at least 4 of them to have something below 50Hz.
Requiem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Requiem Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2013 at 12:34pm
The best drivers for these cabinets are PD-1850 or Void V18.
Bear in mind what Laurin said is true, these bins dont drop very low they are more of an 'all rounder' ,
they drop lower in stacks of 6 coupled, otherwise they dont go very low.
www.requiem-soundsystem.com
Custom Martin Audio WSX, USB & CSG Soundsystem based in Bristol
Goodvibetribe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goodvibetribe Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2013 at 1:42pm
Well as its called the 1850 horn, I'd put a decent bet on saying the PD1850 would be the best driver for it....
And yeah Laurins absolutely right, If you want a horn loaded speaker that goes really, really low; you want scoops.
George c - www.gorilla-audio.co.uk facebook.com/gorillaaudiohire
Post Options Post Options   Thanks (0) Thanks(0)   Quote Soluation audio Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2013 at 9:47am
alright nice thanks heaps for the replys, there turning out very helpful.
My situation is I want 2 bins for low end bass, im looking at a behringer europower ep2500 amp which is 2 channel, do you think I would be better off building 2 scoops or 2 1850 horn bins, and I realise the 1850 horn bins are intended for 18'' drivers but could I use 15'' drivers or would I be better off building scoops with 15s,
THANKS HEAPS GUYS, AS YOU CAN TELL IM NEW TO THIS GAME SO THANKS HEAPS FOR THE POSTS, REALLY APPRESHIATE IT,
 KEEP EM COMING POSITIVE OR NEGATIVE
dylan-penguinmedia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dylan-penguinmedia Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2013 at 10:05am
If you want to use a 15" driver, use a box design that is made for a 15".
And if you want low end bass generally you want a larger cone. (There are exceptions, lab horn, punisher etc)
A behringer ep2500 may well struggle with the low stuff on the end of a v18 or an 1850. They're quite hungry drivers. That being said I've never tried it - I'm sure there are people on here who have though.
pfly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pfly Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2013 at 10:18am
I would go with PD.1850 or Void V18-1000, maybe with 18sound 18NLW9600 or PD.1851
Any of these drivers would work in many scoop designs.
Honestly if you are thinking using 15" drivers in 18" designs, I am not that sure you really realize what low bass means...
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2013 at 11:44am
Clap LOL
Also, no point buying premier drivers, and feeding them with low quality sub amps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Laurin Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2013 at 2:24pm
This is a link for a nice 15" sub for a cheap eminence driver.
This is a good starting point "to get your feet wet".
http://www.ich-war-hier.de/wp-content/uploads/2008/09/kappa15lf_bassreflex_subwoofer.png
jwdrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jwdrain Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2013 at 3:18pm
Brotherhood Sound System in Leeds are selling their old scoops £100 each. Contact sonofalesbian on here
