  New Posts New Posts RSS Feed - my big problem...
my big problem...
wakethetown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakethetown Quote  Post ReplyReply Direct Link To This Post Topic: my big problem...
    Posted: 14 January 2007 at 2:59pm
hi....
I've build a x1....but it wasn't what I hope....it's for subbass and what I need is bass ! ! ! by the way..I've done it...It's a BIG mistake....so what can I do now ? Can I put my p audio sd 18 driver  on a 1850 horn or 186 horn....
I can't build a 4 ways system....
http://www.myspace.com/wakethetownsound
djstefanos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djstefanos Quote  Post ReplyReply Direct Link To This Post Posted: 16 January 2007 at 7:17am
sell it
mykey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 16 January 2007 at 7:37am
block the port's up
Mike Severloh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Severloh Quote  Post ReplyReply Direct Link To This Post Posted: 16 January 2007 at 7:37am
Originally posted by wakethetown wakethetown wrote:
hi....
I've build a x1........
Bonjour,
I am looking for an X1, preferably the letterbox model, īcause I am building a 4 ways system.
Which one did you build, the regular one ?
What material was used ? Iīd  need plywood or something consisting of real wood, no MDF.
Edited by Mike Severloh - 16 January 2007 at 7:40am
Mike Severloh.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakethetown Quote  Post ReplyReply Direct Link To This Post Posted: 16 January 2007 at 8:47am
mykey....what do you mean by block the port's up ? can you tell me more ?
mike severloh.....yes it's the regular one....with mdf...and i live in france !
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 16 January 2007 at 8:50am
cover the port! or make it smaller
see what you think
or sell it to mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Severloh Quote  Post ReplyReply Direct Link To This Post Posted: 16 January 2007 at 12:09pm
Hi,
what a pity, so its not for me. I like France, though.
But Iīll keep my fingers crossed for you.
Btw., the horn idea should work, but didnīt check which oneīs best.
Cheers.
Edited by Mike Severloh - 16 January 2007 at 12:11pm
Mike Severloh.
Tom Umney View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Umney Quote  Post ReplyReply Direct Link To This Post Posted: 16 January 2007 at 2:57pm
Originally posted by mykey mykey wrote:
block the port's up
Well the sound only comes through the X1's ports.
So if you block them all , it will be muffled and much quieter.
Or SD18 can be used in 18 inch scoops.
Edited by Tom Umney - 16 January 2007 at 2:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 17 January 2007 at 12:08am
block the port's up
he wants bass toxic
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakethetown Quote  Post ReplyReply Direct Link To This Post Posted: 17 January 2007 at 2:32am
so you think I can put my sd 18 on a 1850 horn or 186 horn ???
