Lab Gruben 13000 Vs FFA10k Vs Infinite 8 |
Post Reply | Page 123> |
tcourtneyvincent
Young Croc Joined: 04 January 2011 Location: Devon Status: Offline Points: 1146 |
Posted: 30 November 2013 at 10:44pm |
We normally run an infi 8 v1 which seems to spank our 4 pd1850s in Hogs very nicely. For our last gig the Void wasnt back from repair in time so we used an FFA10k, and to be honest it didnt seem to provide what the infi 8 could. The pressure from the hogs hanging off an infi 8 is just insane, but off the FFA it just (pressure wise) sounded weak and clipped well before when i would expect it to for a 1.5k a bin amp.
We have a gig this weekend and the Void is in repair again ha! So im looking for an amp to rent and all the big amps i seem to be able to get my hands on are light weights. Im looking at a Lab 13000, but is this going to be the same story as the FFA? Have come across this http://forum.speakerplans.com/measuredlab-13000-vs-proline-3000_topic60994_page7.html which makes me wary of hiring the lab. If i understand correctly is this thread saying that over 1 second of rms bassline the lab drops down to the same power as the proline? some of the music we play has far longer basslines than 1 second e.g. https://soundcloud.com/ariesandgolddubs/blazeup, so on this track are they saying that a proline will perform as well as the lab? surely not... i must be missing something.... Sorry for the long post, im just wondering weather or not to hire 2 jbl mpx1200 and 4ohm bridge them to get the pressure im looking for of if the Lab will do the job. Many thanks :)
MarjanM
As i can understand from the first page on that topic the fp13000 was put on a resistor load. That is not the way to test the Labgruppens. They can not do sine wave to a dummy load. They simply can not.
But music is not a sine wave and the speakers are not a pure resistive load but more of a reactive load. So two totally different things. Since i have never heard the inf8 i can not say weather the fp13000 can be a comparable swap or not.
Dave FFA
Registered User Joined: 17 November 2009 Status: Offline Points: 318 |
Hey Tom What is the voltage gain of your void amp? kind regards Dave
levyte357-
Patiently waiting for the folks who'll say the Infinite 8 sounded louder due to distortion. There are one or two threads about here comparing Inf 8 amps @ 4 ohms, with higher rated lightweights and the actual observations. Conclusions typically always end in ridicule, and stating merely listening to an amp is no way to quantify which can power drivers more effectively. Having heard Lab Gruppen 14K copies, would recommend you are very careful with the gain when trying out the "real", big labs, they have plenty enough gonads to take out 3x PD1850s per channel if minced with.
Edited by levyte357- - 03 December 2013 at 12:29pm |
MarjanM
Lev, how can that be? We all know labs suck at subs. :-)
levyte357-
Think you'll see from couple of years ago, I said the Lab copies "can be made" to sound better than plenty torroidials (@ 4 ohm stereo), so the originals must be serious. But then again, takes a decent sound engineer to get the best out of any sub amp.
Edited by levyte357- - 03 December 2013 at 12:56pm |
MarjanM
I hope you get my sarcasm, because many people here do claim than LG amps can not do subs.
csg
the only time i have ever had a problem getting "sub" from a lab is when trying to drive a turbosound "sub". But then again, thinking about it, turbosound have never made a sub...
but seriously, there is a big difference between the FP+13000 and the PLM14000, not so much the slightly higher rails and higher current capability, but more to do with the 16A inlet on the 13,000 and the 32A inlet on the 14,000. Lab still state that the 14K will run on 16A, however i have seen one amp take out a 16A c type MCB in seconds, and they are fused internally at 30A. The FFA should be quite capable too, but is optimised really for lower than 4Ω loads, and personally i think it sounds very dry.
Edited by csg - 03 December 2013 at 1:05pm |
burningbush
Old Croc Joined: 25 May 2009 Location: Pictland Status: Offline Points: 5897 |
"sounds like" an input sensitivity issue from the op causing a difference in perceived spl.
levyte357-
I've heard Inf8s compared to other lightweights on same load at a "test", and none of those except K10 came close to providing the same sub spl, on same test set across same stack of subs. LabG FP14/ MC2 E90/FFA10 were "not present". Edited by levyte357- - 03 December 2013 at 2:46pm |
RosscoPico
Young Croc Joined: 31 January 2007 Location: Brighton, UK Status: Offline Points: 955 |
http://www.turbosound.com/docs/products/TFS-900B.shtml But that's a real sub isn't it? Looks powerful going on the specs.
See if you can find a K20, that'll do the trick Edited by RosscoPico - 03 December 2013 at 9:32pm |
.:ELEMENT 5 SYSTEMS:.
The 10,000 Points Club Joined: 09 January 2007 Location: Manchester Status: Online Points: 10919 |
TFS-900B is indeed a proper sub and sounds great too. But it's bloody HUGE.
