  New Posts New Posts RSS Feed - SAE PXM 1450 Power Amplifier Feedback
 Post Reply Post Reply Page  <1 16171819>
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 11 October 2016 at 6:23pm
1 a channel at 4 ohms will get them 9601's singing....
osse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote osse Quote  Post ReplyReply Direct Link To This Post Posted: 12 October 2016 at 6:39am
I've had my 18sw115-8 smell funny when strapped one per side off my pxm-1450, however they can clip a little and still the driver seem okay.
I've also tried two at one side and it seemed to work fine however that was for a short period in the store and no drivers on the other channel.
Question:, if you have high crest factor music, would you benefit more from the increased headroom from the 4r driver strapped one a side compared to if you play low crest factor music?
Mine can give 130 volts but they start to clip barely(doesn't sound bad tho) when the limiter is set at around 95v with a crestfactor of 3.5-4.5 with my drivers.
Edited by osse - 12 October 2016 at 6:42am
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 13 October 2016 at 1:38pm
drivers smelling aint good, looks like the 18sw115 were being over powered...
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2018 at 1:59pm
No point starting new thread...
So could UK resellers clear up few things.
So potential buyer should look for original MK1 or one from the new company/stock?
Bee, I guess that's what you are supplying now?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2018 at 3:14pm
We are already using and sold substantial number of the new onese. They beat SAE in quality.
If you have trouble finding any, we can sort you out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2018 at 3:17pm
Any chance of some internal Screenshots?
What current rating is the breaker on new models?
Any power consumption figures for 4 ohm stereo, at various freqs?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2018 at 6:23pm
Ill check for the pictures.
No data at this moment about the consumption.
The amp is 2x1600W/8ohm and 2600W/4 ohm.
2.66ohm operation without any problem. 2 ohm stable, but we have not made any long term test in real condition yet for 2ohm load.
Edited by MarjanM - 17 October 2018 at 6:25pm
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2018 at 6:29pm
Brand name and model numbers?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2018 at 7:31pm
Ours are OEM under MM-acosutics brand. No public info on our website yet.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2018 at 8:15pm
Who's the OEM then?
Edited by freddymendez - 17 October 2018 at 8:15pm
djkeet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djkeet Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2018 at 10:37pm
Correct me if I'm wrong isn't Marjan OEM YND-CK26 internals, his face plates are nicer than the released ones
Soundbite
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2018 at 10:51pm
Not the stock one. We changed few things.
