  New Posts New Posts RSS Feed - ultimate reflex for sub
MRT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MRT Quote  Post ReplyReply Direct Link To This Post Topic: ultimate reflex for sub
    Posted: 13 May 2014 at 2:07pm
I've been reading from the forum about the differences between reflex and scoop designs for sub bass. Seems to be a lot of opinions, but I guess more or less everyone agrees that scoop is a more efficient way to produce high spl with less amp power, but reflex can go deeper.
So my question is, what would be the ultimate reflex subbass box and driver combo compared to 4 superscoops if the amount of drivers and power needed is not a problem.
Any opinions?
sn95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sn95 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2014 at 3:22pm
×2 the number of scoop,s
KidCreole View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2014 at 4:24pm
Any opinions?
You will need 4 x double 18'' reflex to keep up with 4 x scoops
TONY.A.S.S. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2014 at 5:20pm
I've done a 2x18 reflex which is the same size as a Scoop, or my Scoop anyway, It's a 4 ohm cab so it does perform differently, but it will leave the Scoop standing when it comes to close up low end. No big deal here because you can tune the Reflex cab, whereas you can't really tune a Scoop, apart from moving bits around, but that's not really tuning in the true sense of the word.
Edited by TONY.A.S.S. - 13 May 2014 at 6:29pm
MRT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MRT Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2014 at 8:47pm
So are you saying that if I have 4 superscoops loaded with PD 1850's and 8 reflex boxes with the same driver, with right tuning I get at least the same spl with reflex compared to the scoops  but the reflex goes deeper and doesnt have a dip in the frequency response?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2014 at 9:06pm
Don't worry about the dip in the frequency because you won't cross them that high
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2014 at 9:53pm
Get some of my double 18s and piss all over scoops :-)
jammin75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jammin75 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2014 at 9:54pm
Any opinions?
i used to run 4 18" reflex sound nice and go deep but lack the spl at a distance another sound used to run a pair of g subs same story switched over to a pair supers not as deep as reflex but so much more pressure and i prefer the sound of a scoop Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2014 at 10:02pm
1850 is just horrible in a reflex box.
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2014 at 10:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2014 at 10:44pm
Or 4 2x18's the same size as the Scoop. and regarding what we all term as Throw, most Gigs don't require masses of projection. You'll be surprised ( or maybe not) at  how far low frequency can project with power.
Edited by TONY.A.S.S. - 14 May 2014 at 12:13am
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2014 at 10:49pm
This is the cab I was referring to earlier, made out of 1" Birch 2" baffle etc.
This page was generated in 0.111 seconds.
