  New Posts New Posts RSS Feed - Crown Micro-tech 1200
mgftrophy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mgftrophy Quote  Post ReplyReply Direct Link To This Post Topic: Crown Micro-tech 1200
    Posted: 18 September 2014 at 1:02pm
Hello guys , I have with me a Crown Micro-tech 1200 to test , a friend is trying to sell me for 100€/ 70£ , do you think is it worth nowadays buying a Crown Micro-tech 1200 in good shape to drive some 2 inch comp??
I will try drive 1x B&C DE85 8Ohms + 2x B&C DE45 16Ohms per channel with the micro-tech, it will do the job?
Do you think the amp worth 70£ ? it is an amp with more than 20 years old, I know.. It will be better to buy something new?
It´s gonna be my first Crown experience, I have many QSC MX/ JBL MPX MPA , CREST CA , CREST 8...PRO and 9001 series .
Thanks Jorge
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2014 at 1:05pm
sounds like a good deal, MT series are very similar to the MA series (Macrotech) so build quality is very high
North Staffordshire
Post Options Post Options   Thanks (0) Thanks(0)   Quote mgftrophy Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2014 at 1:22pm
Thanks K. Edwards
imageoven View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote imageoven Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2014 at 1:38pm
I would have thought one of those would fetch £100 - £150 in the UK although I guess the lack of front panel input controls will put off quite a few buyers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mgftrophy Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2014 at 1:41pm
"the lack of front panel input controls" this is one reason that makes me think no to buy..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2014 at 2:24pm
Deffo i would snap it up straight away, i used to have one for many years, no problem with it at all, would of thought too its probley worth quite a bit more, used to have a crown micro-tech 1200 too sure i got about around 140£ for it
nothing wrong with the gains at the rear...imho
grab it now! Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote mgftrophy Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2014 at 11:09pm
I did the test on the Crown mt1200 , and the result was:
first time I fired up, the ODEP light on channel 1 came on immediately, but on channel 2 the ODEP ligth went on after a minute or two! What problem is it? The amp was not used ten years.. always turned off..  and then I was try to get the sound from the two channels and It only came sound from Channel 1! the amp was in Stereo mode switch.
Then I switch off the amp and tried the amp in paralel mono mode , the sound came from channel 1 ok, but the sound from channel two was completely distorted! The light from channel 2 ODEP started getting clearer now, but not completely brilliant as ODEP Channel 1.
Then I thought, let give it a few minutes to warm up, and then I will try again.
30 min after , switch off the amp , and put it in stereo mode again, and tried again , now the sound was ok on the 2 channels , the ODEP light was full on the two channels, and the amp sound nice not distorted , but I still think the channel 2 didn´t sound as louder as channel 1 , but now was not distorted..
What do you sound guys , think about this Crown Micro-tech 1200? is their any problem with the amp? or is just dust and moisture?
Best regards , Jorge.
DjLeco View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DjLeco Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2014 at 11:56pm
Also sound is very neutral, clean and precise.
Edited by DjLeco - 18 September 2014 at 11:56pm
Pinyorouk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pinyorouk Quote  Post ReplyReply Direct Link To This Post Posted: 19 September 2014 at 12:41am
Used it on tops. Excellent!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 19 September 2014 at 9:46am
Open it up and give it a clean. Check the power supply condensors for leaking or bulging. They may need to be replaced on such an old amp.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mgftrophy Quote  Post ReplyReply Direct Link To This Post Posted: 19 September 2014 at 10:38am
Thanks earplug, there are only 2 big condensors inside?
Do you think it is a good buy 100€ for this amp with this fault?
Or do I make another offer 60 €/70€?
Best regards Jorge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mgftrophy Quote  Post ReplyReply Direct Link To This Post Posted: 19 September 2014 at 10:41am
How much is for one condensor? The fault is only on channel two.
But after 30min plugged on the amp makes good sound..
