HOG Scoop |
Post Reply | Page <12345 63> |
Mircea Bartic
Old Croc Joined: 18 February 2005 Location: Romania Status: Offline Points: 2582 |
I presume that Weight to be in birch ply I calculated in MDF, as I can only see this beast used in installs the P-audio SD21EL monsters subs, we designed, were about 180Kg each (and the outer dimensions were similar) |
MarjanM
It will be less in weight than Lab Sub and with more convenient driver. Exactly what i needed.
Tekasis
Hi again Stipe, you may have seen or read on some threads about a driver called the TurboMax 1200 made by RMJ Loudspeakers ?
Anyway, the magnet is not as big as the PD's or the V18's but the depth of the driver is approximately 8.5 inches.
What do think about this driver fitting in the chamber of your Hog scoop ?
From the brief specs below, do think it would be an ideal choice for the HOG ?
depth is 8.25 inches not including front gasket, res. is 32Hz which can be lower if required (26Hz)
staiper
Registered User Joined: 26 February 2004 Location: Croatia Status: Offline Points: 545 |
@madboy - Speaker unit mounted in Hog Scoop becomes unloaded at freq. below 25Hz so I recommend setting high pass filter (subsonic filter) at 25-30 Hz to prevent unit damage and relieve some power for upper range. @Tekasis - I can't find TSP-s for TurboMax 1200 unit. If magnet structure is same or smaller diameter than P.audio SD18 it may fit even without routed grooves... but I can't tell you for sure without exact side-view dimensions. Best wishes, Stipe Edited by staiper - 08 March 2007 at 8:07am |
Rengade Project
Young Croc Joined: 12 December 2004 Location: United States Status: Offline Points: 601 |
I have to thank you staiper for this design!!!May build one and load it with OEM Magnum 18LF to test.
MUSIC SWEET,www.myspace.com/renegadeproject
madboy
Registered User Joined: 06 January 2007 Status: Offline Points: 27 |
i search many sites but cant find
give me here schematic for HPF filter
Edited by madboy - 10 March 2007 at 11:48am |
jethrocker
madboy..you want to build your own HPF?.. search sallen-key high pass filter, or active crossover circuits to find a schematic. There are hundreds about online...
madboy
thanks man , i find hpf filtter |
Rengade Project
There are many crossovers that come with high pass filters so you may already have one! |
jethrocker
yep, check your eq too, if you have one.. quite often a variabale high pass on them.
madboy
i think use this circuit
and with little corection from me :) variable from 10Hz up to 50 Hz
this frequency range OK or not?
CHAMPION
Old Croc Joined: 30 September 2004 Location: United Kingdom Status: Offline Points: 3667 |
Just 2 Questions
1. Why is the chamber do compact / tight, similar to Microscoops, what advantages / disadvantages does this have with sound ?
2. is there a function ofthe baffle being at an angle ?
Thanks
Sticks n Stones
