HOG Scoop |
Post Reply | Page <1 4950515253 63> |
Audio-kid
Registered User Joined: 17 December 2011 Location: westmidlands Status: Offline Points: 140 |
are these images im drooling over staipers re- hog design in the purple and black and also blue ones. im wanting to make my very first ever scoops so im after the plans and cut lists.
cant afford to buy custom build due to being undercut on the hire side these days soooooo want to try building my own. thought id go for 4 x. should be deep and loud enough lol.
Sypa
No,but thanks anyway.Dont use PD although in the future plan to. Is there/are you a distributer for pd in dežela? |
jngggggggg
Registered User Joined: 27 April 2017 Status: Offline Points: 88 |
fellow hoggers!!
i am considering building 4 hogs to use as subs for a 3 way system (subs, kicks, 2way mid/top). are hogs capable of producing below 30hz with high spl when loaded w an ideal driver? tnx!
Sypa
In a stack of six they can play 30hz without problems i would say, on the spl in theory they are flat to 30 with six.
Sypa
Didnt see u want below 30 . First of all are you sure u need that ? I think the driver unloads below 25ish hz .
bass*en*mass
if you really need to go below 30hz -3db you might want to take a look at the othorns..
expensive driver, large`ish cab+needs proper power but should do the job ;) Hogs wont do much with authority below 35ish in stacks of 4? in stacks of 6 30hz -6ish db but def. not happy much lower due to horn path/unloading? |
bzhm
Registered User Joined: 30 June 2014 Status: Offline Points: 10 |
Hi,
Does anybody know which speaker is used by Imperial Sound Army in their hogs ? Thanks,
Matt276
Registered User Joined: 12 June 2015 Status: Offline Points: 20 |
It looks like Turbomax
paulus
was tmax with green surround know i believe they are on turbomax red eyes
TRENDSETTER SOUND SYSTEM
bzhm
Hi,
yes previously tmax with the green circle but now all black... Do you think it s this one now? http://rmjloudspeakers.com/acatalog/info_210.html RMJ Red I 1500 18" MODEL Red I 1500 Fs 35.4286 thx
Matt276
or maybe :
RCF LF18X401 |
bzhm
ok thanks, another possibility !
I that can help i think it s driven by ffa10k...
