  New Posts New Posts RSS Feed - MK III  -Eminence KILOMAX 18- ???
CINCYSTAR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CINCYSTAR Quote  Post ReplyReply Direct Link To This Post Topic: MK III -Eminence KILOMAX 18- ???
    Posted: 12 February 2015 at 5:16am
Is the Eminence Kilomax 18 a decent match for MK III?
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2015 at 4:02pm
MK III what? Match regarding what? Most people on here haven't developed telepathic senses just yet.... Wink
JR.junior View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR.junior Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2015 at 4:27pm
RHINO MK3?
burningbush View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote burningbush Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2015 at 4:27pm
Kilomax pro-18 is for a sealed or reflex type enclosure, AFAIA.
I presume you mean the Mykey Rhino MkIII which is a mini-scoop, probably best perceiving it as a horn cabinet.
So will a reflex driver go in a horn cabinet?
No.
Opening my mind and letting the waves in, man.
smithshorn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smithshorn Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2015 at 6:27pm
Could be referring to the MS-18 Mk.III.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CINCYSTAR Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2015 at 6:45pm
Yes the ms-mk III is what I am asking about... I have several Kilomax at my disposal and I have been wanting to buils some small super type scoops....suggestions plaese....thanks in advance
'IF YOU ARE A BIG TREE,WE ARE THE SMALL AXE"
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2015 at 6:55pm
These guys run 4 double reflex loaded with kilomax
http://www.talawa.fr/Digital+Steppaz+Soundsystem
Post Options Post Options   Thanks (0) Thanks(0)   Quote burningbush Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2015 at 1:07pm
Reflex, not hornloaded.
onefootskenk77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote onefootskenk77 Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2015 at 8:06am
There are guys who use kilomax in scoops and are happy with them,there is a guy in Birmingham who has 8 kilomax.......
EMPIRE SOUND
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2015 at 9:08am
The 15" Kilomax in a tapped horn.
The 18" in a very small tapped horn.
A pair of Kilomax 15 in a tapped horn (±1.5dB 33hz~110hz!).
Hope that helps.
Edited by _djk_ - 14 February 2015 at 9:13am
djk
tnbigbass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tnbigbass Quote  Post ReplyReply Direct Link To This Post Posted: 26 July 2022 at 12:52am
Hi, can you have the parameter for Hornresp? I'm not good at akabak...
Thanks.
