Preamp/crossover DIY |
Author | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
[Djo]
Registered User Joined: 29 October 2014 Location: Paris, Fr Status: Offline Points: 24 |
Posted: 14 April 2015 at 10:12am |
Hi!
I'm very proud to share with you a nice preamp/EQ/crossover that I made. The purpose was to have a compact board with everything fixed onto it ; the accusafe, maxamp and velleman vu-meter k4304. It simplifies a lot the assembly in my boombox. (a classic 2-way reflex box) There's a 6db gain, mono input buffer (I use a passive stereo to mono cable merger for mp3 player, so you loose about 6db), it is helpful when I plug in my electro-acoustic guitar or my old mono analog drum box which don't have a very hot signal output. Audio is then processed by a five band, pseudo two octave, graphic equalizer, (+/-12db @ 100Hz, 300Hz, 1k, 3k, 10k) that allowed me to compensate for my enclosure design flaws without any problems. It's really a set it and forget it adjustment with trimpots. Schematics where found on a Texas Instruments note by Bruce Carter. http://www.ti.com/lit/an/slyt134/slyt134.pdf Next, there's a one knob wide range tone control to let the user adjust the frequency response smoothly for different sources. This is a great design explained by Roy Mallory here : http://roymal.tripod.com/ReverbTone.htm Finally, the 12db / octave Linkwitz Riley Crossover is based on Rod Eliot work, I just adapted it to a single power supply. http://sound.westhost.com/project81.htm I made the assembly on a perforated board, but I used good quality polypropylene caps, and nice OP amp. (OPA2132 for input buffer, NE5532 EQ/Xover, TL072 gyrators) I measured about 35mA power consumption for the whole processor, which seems to be great since those AOPs are a little power ungry. There's not a lot of headroom because of the 12V power supply, but it sounds excellent and there's clearly no noise at all! I need some time to clean my notes and I'll post my schematics. I hope this design will be a nice inspiration for DIYers. Cheers! |
bitSmasher
Beautiful work!
I would love to DIY similar, but instead take the lazy way out with premade parts |
amlu
Young Croc Joined: 30 November 2009 Location: london Status: Offline Points: 740 |
Nice one. How did you adapt the circuits for 12v use?
WesleyK
Registered User Joined: 24 December 2012 Status: Offline Points: 90 |
Very coool! Hope you like the combination ^^!
Looks like you have a extra set of holes under the accusafe, would the maxamp fit that pattern? If so, it should be able to fit the new AccuSafe i'm working on at the moment :). Edited by WesleyK - 14 April 2015 at 11:18am |
[Djo]
@bitSmasher : Premade parts are necessary with crucial designs like the maxamp and other SMD boards. But DIY is great because you can do something that fits perfectly your needs/projects.
@amlu : With a single power supply, you need to bias all your AOP to Vcc/2. Look at the other parts of the texas instruments documents, if memory serves me well, there's an example of a classical way to do it properly by using an AOP to buffer the bias voltage. Main drawback is that you'll need to add some coupling cap on the audio path. Here, I used Nichicon bi-polarised electrolytic caps, they are really great! @WesleyK : The accusafe/maxamp combination is awesome, clearly the way to go, and those boards are very well made! There is some room around the accusafe, it should be possible to drill some holes for the same pattern as the maxamp. The v3.5 is very great, simple, ultra small, working perfect! Have you got some informations about the feature of the new accusafe? Edited by [Djo] - 14 April 2015 at 12:14pm |
lutkeveld
Young Croc Joined: 23 September 2013 Location: The Netherlands Status: Offline Points: 517 |
Awesome work. Looks very clean!
[Djo]
Thank you lutkeveld!
I made a quick video test so you can see the action of the processor. Hi and low outputs of the crossover are merged passively, and you can see that there's no dip at the X frequency. Schematics will follow very soon. Edited by [Djo] - 20 April 2015 at 9:14am |
[Djo]
Hi!
Here's my schematics : If you want to follow my layout, be careful to the size and footprint of the components, capacitors especially. A good solder skill is required. 5 band EQ and crossover – BOM
jerronimo
Registered User Joined: 11 July 2009 Location: Nederland Status: Offline Points: 438 |
Awesome work
Edited by jerronimo - 05 May 2015 at 1:23pm |
audiomik
Old Croc Joined: 06 April 2010 Location: Bath, UK Status: Offline Points: 2962 |
Good work!
You might find advantages in coating your Vero Board and others with lacquer - Specific types available from RS, etc - Conformal coating is one good one to cover component side as well as the vero board itself is prone to moisture absorption - voice of experience! You will be exposing your system to condensation using it outdoors. hope this assists Mik Edited by audiomik - 05 May 2015 at 1:54pm |
Warning! May contain Nuts
[Djo]
Thanks!
Great advice, I hadn't thought about the moisture/condensation issues. |
slaz
Top job that man !!
Very close to something I would love to have actually (been muttering/murmuring about it for a whle, never done anything). Ideally I would have an additional HP filter (switchable) at about 55-60Hz or so - 12dB/octave should do..... and possibly bring the EQ pots out to proper external ones with knobs. |
