RCF LF15X401 In Scoops |
Ruggeddave
Registered User Joined: 17 August 2012 Location: United Kingdom Status: Offline Points: 67 |
Posted: 17 March 2016 at 8:43am |
Aye up,
Got a 15" scoop, wanting to know if the RCF driver will work in it. The box was 'designed' around the OBERTON XB700 and thus has a chamber size of 30L (with driver in). The throat area is 481cm^2. I've changed my mind a little (as the RCF will give me 3db more output before XMAX, according to my sim), can I get away with putting the RCF LF15X401 in there? My main concern is the VAS is 140, and thus the chamber size of the box will be too small. I'm sure someone will be along to tell me the only way to find out is to try one, but I want to know if I'm way out here or it might work. I'm aware Jah chalice soundsystem use this driver in their scoops, They are a lot bigger than mine mind. T/s parameters of the RCF:
JR.junior
Good driver for scoop.
Dub Specialist Sound
Intersting, just about to build a scoop for testing for this driver
DJ123
Registered User Joined: 02 March 2010 Location: UK Status: Offline Points: 60 |
what about the RCF LF18N451 will that work good in a super scoop cabinet ? thank you
levyte357-
I really don't rate 15" Scoops.
nickyburnell
Yeah, agreed. two of the most disappointing things for modern EDM : JBL 4520 and W Bins. They need sub, plenty systems found this out quick in the early 90's and that wasn't really sub as it is now. However, if the 15's scoops are to play older music then could be a nice retro option? |
levyte357-
You can buy 4x Used unloaded 18" SteveB scoops, drop in 4x used PD1850s, spend £700 on used 5K heavy, or big SAE, and have enough sub for 500 people. Using 15" Scoops, dunno, dunno, dunno. |
