  New Posts New Posts RSS Feed - Schematics for Electro-Voice Zlx12-P
 Post Reply Post Reply Page  <1 1516171819 32>
grawitserwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grawitserwis Quote  Post ReplyReply Direct Link To This Post Posted: 05 February 2018 at 3:52pm
Hello Voron, can you please send me the schematics for the Electro-Voice ZLX-15P and the ZLX-12P
Greetings and thanks to polish :)
My mail : grawitserwis@gmail.com
MacJones View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MacJones Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2018 at 1:23pm
Hello Voron can you please send me the schematic for Electro Voice ZLX 12P?
many thanks Gareth
gmacjones@gmail.com
Al.C. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Al.C. Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2018 at 5:36pm
Hello,
Voron, first I'd like to say thank you for what you're doing here. It's totally amazing, and it restores my faith in humanity.
I've got a -12P and a -15P, both with problems. The amplifiers appear to be identical. The -12P has exactly the same problem that so many here have, namely burnt resistors R61-R71, and an apparently shorted Q1. The value of those components is legible on the -15P board, so I'll be fine there.
The -15P has an odd problem: it's very weak in the bass. I do get clean signal through it from around 50Hz up to 12 or 14 KHz, but much quieter below about 300Hz. So guess what?
Could you please send me, too, a quality copy of those schematics for diagnostic purposes? My email: albertcamus99@protonmail.com.
Thank you!!!
-Al C.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MacJones Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2018 at 6:18pm
Many many thanks Voron for very prompt reply to my request
Post Options Post Options   Thanks (0) Thanks(0)   Quote Al.C. Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2018 at 7:04pm
HAHAHA!
File under: "Hey, what does this button do?"
File under: When in doubt, read the instructions.
So I got to thinking. A clean, bass-poor signal? Well that sounds like someone just turned down the bass control... So I actually read the manual for the ZLX-15P, and the part in the "DSP" section about adjusting for an added subwoofer stood out. I put the thing back together and turned it on, and sure enough, it was set up for a bass roll-off at 120Hz to compensate for a (nonexistent) sub.
Can I still charge the speakers' owners for the repair?
HAHAHA!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Al.C. Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2018 at 7:06pm
P.S. sorry to have bothered you Voron, and thanks again for your efforts!
voron View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote voron Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2018 at 8:37pm
no problemWink
kassie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kassie Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2018 at 2:57pm
Hi Veron, please can you send me the schematics for Electro Voice ZLX 12P?
The power supply is pulsing - I assume a shorted part in amp or pre amp.
my email is. kaspaas.one@gmail.com
Much appreciated.
Br
Kassie
Post Options Post Options   Thanks (0) Thanks(0)   Quote kassie Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2018 at 1:07am
Thanks Vonon, received.
Much appreciated
Kind Regards
Kassie
Post Options Post Options   Thanks (0) Thanks(0)   Quote kassie Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2018 at 8:18am
Morning Voron,
Are there any power supply schematics for Electro Voice ZLX 12P?
Please can you also send me the power supply schematics if available?
Much appreciated.
Br
Kassie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Al.C. Quote  Post ReplyReply Direct Link To This Post Posted: 17 February 2018 at 7:19pm
Hi Voron,
Me again... I've rebuilt that resistor array (R61-71), and replaced Q1, but still no go. Now I suspect Q2, which will be hard to find... But without a scvhematic I can't be sure of anythhing much. Would you be so kind as to send me the power board schematic too? THANK YOU! albertcamus99@protonmail.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Al.C. Quote  Post ReplyReply Direct Link To This Post Posted: 18 February 2018 at 9:46pm
большое спасибо!
