My first 186 build, A/B test with Earthquake B36 |
Post Reply | Page <123 |
Dub Specialist Sound
Alternative , use wood inserts..m6..m8 ect
tha give us less trouble imho
Dutchman
Registered User Joined: 23 March 2013 Location: GENT Status: Offline Points: 365 |
How did this end up? Happy with the sound? Are you in belgium or Holland?
We need more SPL!
RemyK
Registered User Joined: 02 May 2016 Status: Offline Points: 37 |
Well, i use them and they punch verry good.
i build the first one in MDF and now i have 2 in "Multiplex Okoume supergarant" is use them on this QSC powerlight 4.0 amps (2 in bridge per amp) I had pictures but the forum was not working when i was in the build. and now a year later i don't have the pictures anymore because of a ransomware virus :-( It this moment i'm thinking to build a CUBO18 to A/B compare them. The Earthquake B36 is a little less good sounding then the 186 in my A/B tests. The 186 is more difficult to build but its better in sound. I live in Belgium next to Maastricht (NL)
Edited by RemyK - 11 May 2017 at 12:48pm |
nickyburnell
A little note on t nuts in mdf. A lot of issues come about when (installing or removing) people let the weight of power drill push down on bolts. Pull them up tight manually with a ratchet in first place really helps. You can nearly always get a couple of turns more than even the best cordless.
ape3435
Young Croc Joined: 23 August 2009 Status: Offline Points: 552 |
When drilling, make sure the t-nut holes are nice and straight with the driver holes; use your fingers to put the bolts in as far as then tighten with allen key. You could also reinforce the baffle edge underneath with birch or similar ply that will hold the nuts better.
Been saying for years on here,forget t-nuts alltoghter
pain in the arse really , that FALL out sometimes wen tha feel like it wood inserts all the way man, impact driver inserts done!! lets not forget ppls we not bareing down mega tons of force, like some ppls think you have too
VECTORDJ
Young Croc Joined: 11 June 2006 Location: United States Status: Offline Points: 514 |
A+ to A/B test
RemyK
Meanwhile also the 186 horn compared to the Cubo18:-)
actually 2x 186 vs 1x Cubo218. same, same amplifier speakers. The 186 Horn is clearly more power, more pressure. But you have 2 x as much wood. For practical reasons, with transport is 2x Cubo218 better than the 4x 186. Cubo218 also sounds deeper with the same settings (low cut 40 Hz) |
