  New Posts New Posts RSS Feed - Crown XS1200 Amplifier PIC Controller
CaptenMorgan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CaptenMorgan Quote  Post ReplyReply Direct Link To This Post Posted: 28 December 2016 at 8:22pm
hi guys
I have 2 crown amps   xs900 and xs1200 for repear . on xs900 the pic 16c57 is damaged.
I need the hex to program a new pic .Is the same hex with above Pulse 2x1100? .can I use it?
TMH Music View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMH Music Quote  Post ReplyReply Direct Link To This Post Posted: 28 December 2016 at 11:53pm
Sorry to hijack this thread, but as the owner of an XS1200, I am curious as to people's opinion on the reliability of this amp. Is this PIC controller problem a known fault? Any advice on how to keep this amp reliable would be gratefully appreciated.
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 29 December 2016 at 12:37am
Failure of the PIC controller is fairly uncommon.  I've only seen one myself on an original Pulse.
Biggest tips for keeping any amp reliable are keep them clean and dry and don't drive them hard into low impedance loads.  Although the Pulses/XS Series are rated for 2Ohm operation, I wouldn't.  They are best suited for mid-top applications which they sound very good on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CaptenMorgan Quote  Post ReplyReply Direct Link To This Post Posted: 29 December 2016 at 7:00am
In my case the  pic falure cased by 5v supply. A bc546 sorted and pass 30v to pic.
xc900 and xs1200 is exactly the same exept some smaller power supply capasitors. Can i use this Hex?
xc1200 and pulse use the same Hex?  I mast be sure.
thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 29 December 2016 at 6:21pm
you'll need the firmware version, it'll be printed on the label on the micro.
North Staffordshire
simonp1100 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote simonp1100 Quote  Post ReplyReply Direct Link To This Post Posted: 29 December 2016 at 7:09pm
Hi,
PIC's info marked on them is as follows:--
Crown XS1200 = REV.:1.09 (CS.: 8778).
C-Audio Pulse 4 X 300 = (RX5066 V1.06).
I think (correct me if i am wrong) but software RX5066V106 is for the 4 channel amps & RX5066V107 is for the 2 channel amps. Hope this info helps.
jacethebase View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 29 December 2016 at 10:30pm
I have loads of Pulses and a fair few XS1200's and 700's all mine are fairly reliable and sound great on wedges.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CaptenMorgan Quote  Post ReplyReply Direct Link To This Post Posted: 30 December 2016 at 1:31am
both amps  xs 1200 xs900 have the same version   rev109 cs 8778  .
 you think RX5066V107 is  ok to  me or is only for 2 channel pulse ?
Post Options Post Options   Thanks (1) Thanks(1)   Quote simonp1100 Quote  Post ReplyReply Direct Link To This Post Posted: 30 December 2016 at 8:00am
I would use the RX5066V107 software. Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote CaptenMorgan Quote  Post ReplyReply Direct Link To This Post Posted: 01 January 2017 at 11:45am
ok
thanks to you  one amp have a chanse to return fron the land of dead amps Tongue
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 01 January 2017 at 2:05pm
I have V1.09 if you need it
North Staffordshire
Post Options Post Options   Thanks (0) Thanks(0)   Quote CaptenMorgan Quote  Post ReplyReply Direct Link To This Post Posted: 01 January 2017 at 3:31pm
can you send me or give download ling ,please?
