Some general newbie questions |
Post Reply | Page <12 |
grizli
New Member Joined: 02 September 2016 Status: Offline Points: 8 |
Well actually I am looking for some small hints, this is home audio use, not professionall. ---- About vented boxes, for example why this box does not have square shape, but trapezodial? If box of the same volume would be make square and simple, how will it affect speaker behavour? (vented box) http://www.fane-international.com/downloads/Fane%20EN1501%20Enclosure.pdf In this case I presume that horn would not fit if speaker would be square. (than volume will be larger)
Edited by grizli - 05 September 2016 at 7:44am |
KingGwarn
Registered User Joined: 19 March 2016 Location: Brighton Status: Offline Points: 193 |
Hello again! Not sure how low the mids go...I currently run them down to 250hz and have the bass do the rest but will be changing that when my hog scoops come along and the reflex boxes take on kick duty... The crossovers have adjustable filters and I also have an active crossover (in my amp rack) that I can adjust too. In regards to bass drivers and filters...I'm not sure but many amps (including mine) have settings to use a high pass filter to cut out those <30hz frequencies so I just use my amp for that. Wish I could answer your other questions but I haven't been in the game long enough to answer ;) Hope you find out and good luck with the build!
Soundman inna Brighton town
King Gwarn Sound System |
