  New Posts New Posts RSS Feed - B&C 18SW115 enclosure design
 Post Reply Post Reply Page  <1 5678>
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2018 at 8:09am
Put it in a decent tapped horn if you need that sort of SPL from one box.
Crashpc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crashpc Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2018 at 8:28am
Agreed!
BASSHORSE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BASSHORSE Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2018 at 9:50am
or ass mini scoop
JAckDR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JAckDR Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2018 at 6:05pm
The Qsub has an output of 133 dB (peak) and is a box in bass reflex with a lower speaker than the B& C..Also the brand is a guarantee! For the tapped horn, some ideas? I'm open to all options! There is no project for this speaker in the live range (for which it was created) ...
Edited by JAckDR - 10 January 2018 at 6:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crashpc Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2018 at 6:40pm
133db peak is very vague parameter. Seriously.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JAckDR Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2018 at 8:03pm
The classic parameter in a data sheet of a professional loudspeaker...There are those who lie and those who indicate a true parameter. None indicates the peak frequency ..
Post Options Post Options   Thanks (0) Thanks(0)   Quote JAckDR Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2018 at 8:04pm
does anyone have a project for the live sector?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crashpc Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2018 at 8:08pm
JAckDR: That´s why it´s close to meaningless, unless we put it in certain situation and usage scenario.
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2018 at 8:29pm
qsubs are tuned quite high, not much below 40hz.. if you are fine with that a rel. high tuned tapped horn might be the most economic use of a single driver? (if size doesnt matter..)
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2018 at 11:00pm
Qsub is a shitty box. It that is what impress you, your standards are quite low.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JAckDR Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2018 at 11:12pm
I listened and worked with the original and I can assure you that it's not just a shitty box. The timbre is excellent even if the project is rather simple. Together with the satellites of the same series it was a standard for quality live productions ... We're probably not talking about the same loudspeaker ...
Edited by JAckDR - 10 January 2018 at 11:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JAckDR Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2018 at 11:29pm
Obviously I do not say that it is the best on the market, but I see it as a good starting point
This page was generated in 0.469 seconds.
