B&C 18SW115 enclosure design |
Post Reply | Page <1234 8> |
Crashpc
Registered User Joined: 26 February 2008 Location: Czech Republic Status: Offline Points: 465 |
Thats a shame :-D
Hope you like them after you test them. I found these to be superb compared to previous B&C versions. The bad side is that now they spoiled me with 21DS115. The speaker looks like "business." Or rather GORE. ;-D Two 18SW115 are stronger still, so be careful of yourself at home. We dont want to loose you. Edited by Crashpc - 14 January 2017 at 6:02pm |
smitske96
First results with the recommended enclosure from the b&c website was disapointing.
Not much SPL and overal not good sound reproduction. Next weekend I will also build a TH-18 tot do some testing.
Crashpc
That´s weird. It should do a lot. Of course, not very sensitive driver, but goes deep easily. Also modern high-Bl drivers with higher impedance need higher voltages and equalization to drive these at rated powers. Conventional usage is not a way to go for best outcome with these.
Marko
Registered User Joined: 28 January 2009 Location: Croatia Status: Offline Points: 274 |
B&C SUB 18 needs heavy bracing inside to stop panels from resonating! This is really important especialy with this monster driver! |
BASSHORSE
Young Croc Joined: 19 September 2007 Location: wolverhampton Status: Offline Points: 1160 |
ive A&B the 2 differant cabs ,the b&c sub & this mini scoop,..ok the sub was a lot smaller but also a 3rd of the output of the scoop,. to me that speaker was a waste in that b&c sub,.probably good for the smaller b&c's but not the sw,.try & get your hands on a mini scoop,i suppose the tapped horn would work aswell but as marko said,, what ever cab you go for you need some real solid bracing,.
Edited by BASSHORSE - 17 January 2017 at 7:57am |
Teunos
And whatever your findings may be, if you want to test them in some huge(1x1x0.6m) tapped horns to see what they can do, i am still curious how these drivers would perform in my Tapped horns. Where are you from?
Best regards,
Teun. |
osse
Registered User Joined: 26 August 2013 Location: Sverige Status: Offline Points: 84 |
Those mini scoops look rather big still, how many liters is that one, 400?
I've built a pair of keystones with these drivers that I use atm, monster output very clean sounding, solid nice kick 100-110 hz. Could bark a bit more tho to my taste for techno but I guess it's due to the low distortion.. sounds different compared to my flh's which has a nice compression bark up close and more 'snappy' sound but not even close in output at a little less than double the liters(I have four t30 3012lf loaded, eight would probably be somewhat equivalent with two keystones) |
smitske96
The used design was the S18CN from the B&C site, and was build with the recommended bracing.
The TH-18 is preferred with it's dimensions. @Teunos I'm from Helden (near Venlo) ;)
smitske96
Th-18 it is! The output was very nice, and deep enough.
They will have a full grill, and two m20 plates for a top cabinet (what will be the next project). The panels for the cabinet will be done by a professional company. Paint and overal finish will be done by myself.
mini-mad
pics or it didn't happen....
t.geessounds
Young Croc Joined: 10 May 2010 Location: US... New york Status: Offline Points: 908 |
ya pic please
smitske96
Unfortanetely I have no pics from the TH-18
But I have some of the recommended B&C enclosure.
