  New Posts New Posts RSS Feed - GS3 to led
GS3 to led
 Post Reply Post Reply Page  <1 23456 14>
Steve20131 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2018 at 8:30pm
Had to be done in the house as it wouldnt go above 23 degrees outside...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 25 February 2018 at 9:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 25 February 2018 at 9:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 25 February 2018 at 9:51pm
Prism rotating wheel.  Cleaned and ran oil through until it ran clear.  Also did the same with other gobo holders and focus assembly.  May not be the clay paky recommended lubricant however,  3 in 1..
Not as fussy as I would like for all jobs but alot tidyier than before.  Also used epoxy neatly on prisms, removed the over enthusiastic use of silicone sealant that had been used in the past..
Edited by Steve20131 - 25 February 2018 at 9:56pm
JonB67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 26 February 2018 at 11:10am
Keep up the good work steve.
Following this thread with interest as i imagine lots of others are too.
Jon
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 26 February 2018 at 8:09pm
All clean and back together
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 26 February 2018 at 8:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 26 February 2018 at 8:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 26 February 2018 at 8:12pm
The only colour I could find was grey for the grills,  although they are a bit too far gone,  rust and damage wise
Edited by Steve20131 - 26 February 2018 at 8:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 26 February 2018 at 8:19pm
The picture above is the gs2,  the camera doesnt show but edges are clean & the focus will go from 180 feet down to 4
Can't really test more until the lux meter gets here and I can see where the best places for the lenses to be (Led right against collimator,  just inside focus point or at focal point)...
Also waiting for 60 degree lens,  might catch more light..
Edited by Steve20131 - 26 February 2018 at 8:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 27 February 2018 at 12:31pm
https://www.ebay.com/itm/Switching-Power-Supply-350W-60V-output-60VDC-input-90-132VAC-180-264VAC-Nema34/162414107815?hash=item25d0a29ca7:g:wgkAAOSw6aVUoglR
May try this supply for the next 500w.  Do some lux tests,  I think it may be surprising efficiency wise..
