  New Posts New Posts RSS Feed - GS3 to led
GS3 to led
 Post Reply Post Reply Page  <1 1011121314>
Steve20131 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 09 April 2018 at 6:20pm
Hi no the led is bolted with transfer paste inbetween.  You can use high temp epoxy but is a pain if you need to remove it (a chisel job).  I was going to use the cyanoacrylate with aluminium oxide the same way people use it with baking soda.  It will be strong and transfer heat.  The led with the right size sink wont get to 80c.  However to make sure I plan to braze it.  Might be easier than pop rivets..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 09 April 2018 at 6:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 09 April 2018 at 6:32pm
New box of led's to do all the other scans
Will have a crack at it all again at the end of the month....
Edited by Steve20131 - 09 April 2018 at 6:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 14 April 2018 at 5:46am
Hi folks,   I've completely redesigned my plans it but it's too complicated to explain, I'll just take photos...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2018 at 1:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2018 at 1:02pm
I spent two days trying to braze 6mm to 1mm and decided it was impossible so the only other option was to cut slots.  Then mixed epoxy with thermal paste
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2018 at 1:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2018 at 1:06pm
It fits with 1mm clearance.  I just have to butcher the chassis to channel the airflow through it..
Edited by Steve20131 - 06 May 2018 at 1:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2018 at 3:06pm
Just waiting for parts then I can test it....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2018 at 9:46pm
Todays new old purchase.  Two heads,  gs2 and stagescan but pretty much identical,  to be tidied up and new mirrors
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2018 at 6:55pm
May get a chance to do a test today :o).  The stain on the baseplate is baked on sticker from when I tried to braze it,  I may try to get it off more sometime...
