GS3 to led |
Post Reply | Page <1 11121314> |
Steve20131
Ok, first switch on and no bangs or fizzing. I had it on really low to begin with. I forgot how powerful the twin clay paky fans were..
This was half power after 3 or 4 minuites, looking good |
Steve20131
After 15 mins on full power it settled between 54.3 and 54.7. Well pleased. I expected early 60's and the ambient is around 19c so this is way cool. Changing the leaf orientation and opening/blocking various air holes has worked really well
Steve20131
Ok, to take pics of the gobo's it had to go down to approx 1/3rd power, or the phone just blots out but it looks fine to my eyes and the colours are all of equal brightness The waviness is the envelope it's shining on
Steve20131
The last one is open green on full gain. It looks saturated green but the camera goes white. It's very bright and fills the room green. I might not be able to be back for a while but superb first results. Also thanks for the ideas, someone suggested a external pot which I put on to control brightness (I have ordered a logarithmic one) there's also a few other changes now I know the cooler works well. The light meter won't measure close up but will test more when I'm off next....
mini-mad
You're doing superb work here my friend... don't ever stop!
I like you are paving the way for people to have a little stab at this themselves after watching this thread. Keep up the good work.. even if there's a few weeks or months inbetween posts... I'll see be watching. |
Steve20131
Hi thanks. I'll keep going, most of the hard work is done, just doing the same on other units..
4D
Indeed sir a top thread thank you for the edification
djeddie
Steve20131
You wouldn't be able to do the same with moving heads as sufficient cooling would be too heavy. Hence why I chose scanners, plus they move faster and have less problems. Thanks for all the compliments. I'm a total cheepskate, which is why I'm so determined to make a permanant bulb. Plus the arc ones have blown up before
Steve20131
I also bought thermostats, I may fit them because they are a good and cheap safety measure but in the end they were so cool it didnt need it
4D
I am very keen to convert some old studio due mini city to led at present they run a 150watt hmi passive cooling, I was wondering how do you rate the cmy colour mixing using LED in your scans and what would be the maximum power led one could use in such circumstances.. They get pretty hot after a few hours with the hmi and the thermal cutout is rated at 110c
csg
in all honesty Ford, i'd sell those on as they are and get some IP rated LED units that mix colours additively. They will probably be cheaper than doing the conversion, certainly run cooler, more efficient in terms of power usage and more than likely a lot brighter.
