  New Posts New Posts RSS Feed - Neodymium drivers in Scoops
Timekeeper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timekeeper Quote  Post ReplyReply Direct Link To This Post Topic: Neodymium drivers in Scoops
    Posted: 12 May 2017 at 4:54pm
Back with another question.
not many people seem to use neodymium drivers in their scoops. My research has shown, that in the early days of neodymium drivers the neodymium drivers used to demagnetize under heat.
We use 2 PD.N 18BR40 in a customised G-sub, have been doing so for 2 years, without any problems or signs of damage.
has the R&D of neodymium drivers found a solution to this problem yet?
Are there other reasons for the fact that noone seems to use them in scoops?
thanks for any input!
Edit:
VAS seems significatly lower with neo drivers. Is this the reason noone uses them?
Edited by Timekeeper - 12 May 2017 at 5:16pm
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2017 at 11:08pm
Used (s/h) unavailability and new price?
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 1:51pm
18 sound NLW9601, in right Scoop, with right pre-amp, Sub amp, Speaker cable, smokes 1850 in ASS S118 Scoop.
Been there, seen it, done it.
Not for everyone though, due to price.
EDIT:Have Compared 4x in Lev .44 powered by Inf8MK2, vs 4x ASS S118 Loaded with 1850s.
Edited by levyte357- - 13 May 2017 at 1:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 2:23pm
It took you only 5 years to realize this :-)
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 2:24pm
Price aint that bad if you know where to get them from.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 2:37pm
Completely correct, yes. LOL
But remember, years ago, Most scoops around were optimal for 1850.
My Lev .44s, were deliberately optimised for drivers "a little looser/warmer", than PD1850 series 1.Wink
BASSHORSE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BASSHORSE Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 4:21pm
sw115 blows the 1850 out the water aswell Nuke
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 8:35pm
May be,  but its a completely different sound .
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 11:02pm
Yes, it goes proper low :-)
Post Options Post Options   Thanks (0) Thanks(0)   Quote BASSHORSE Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2017 at 6:40am
|& i agree with your ther mate,..i still love the s118 with the 1850 grunt & punch,,plays nice & tight,.but for the low notes,no compatition...sw thunders & rolls...
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2017 at 7:30pm
18sw115 parms strongly suggest it would work well in my Scoop.
However, no of 1.9% is exceedingly worrying in my books.
Regardless of what some people say, low no figure means reduced sensitivity, means more power to get it to impress, than a similar 18" of higher sens.
I'm "guessing" the 18NLW9601 would outplay the B&C, with much less power input.
luton_soundman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote luton_soundman Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2017 at 7:50pm
U want lows from a 50 put it in a better scoop. Put a 50 in a smini or the sb version i had. And then compare that to your big chamber/throat box. Then the difference isnt as big. But no point comparin that b&c to a 50 when theres a 51. 21" wise the 18sound is stronger than the b&c so id bet thats the same for 18" too.
