186 Horn - Throw them in the dumps? |
Post Reply | Page <123 |
Brutus
Registered User Joined: 27 November 2015 Location: Utrecht,Holland Status: Offline Points: 101 |
more boxes is your solution, just more... so build another 12 is a great option.
and because it is so obvious, use one type of driver in one type of cabinet always. keep it simple, keep it uniform, Edited by Brutus - 16 May 2017 at 12:07pm |
bass*en*mass
drivers not ideally suited to large FLHs might not survive large stacks of them either..
(rising force on the cone/motor due to "air-mass/pressure" simpy put..)? |
Ruggeddave
Registered User Joined: 17 August 2012 Location: United Kingdom Status: Offline Points: 67 |
If you are using large multiples, you would be better off with the 1850 horn really
Keen
why? it's the same horn. different chamber size
Sapro2
Registered User Joined: 31 January 2015 Location: Somerset Status: Offline Points: 354 |
This but also the clue is in the name, the 1850 was designed for PD1850 and the 186 was designed for the PD186. Stick with your 186 horns just build more. |
Splat Soundsystem
Baby Sham pram Soundsystem Sapro - SoundCloud https://soundcloud.com/sapro DJ Sapro. West country free party DJ and Producer. |
Mikkel
precision devices 186 (for which the 186 horn was designed around) isnt a horn driver. You'll be fine with the 18sound. With your music i dont think there will be much content below 40 hz, plus the f118 crossover recommendations are a bit funny as they certainly dont produce anything usable below 40hz anyway. As mentioned before just build more 186 horns if your happy with the sound of them.
Edit: Typo Edited by Mikkel - 02 June 2017 at 11:43am |
Dutchman
Registered User Joined: 23 March 2013 Location: GENT Status: Offline Points: 365 |
To me 186 horns sound a bit soulless.. Maybe build lab horns, punishers, SBH?
We need more SPL!
DaLI3N CZ
New Member Joined: 24 December 2023 Location: Czech Republic Status: Offline Points: 4 |
what subbass you used to get down to 20hz?
