  New Posts New Posts RSS Feed - SUPER SCOOP ALTERNATIVE
Five & View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Five & Quote  Post ReplyReply Direct Link To This Post Topic: SUPER SCOOP ALTERNATIVE
    Posted: 18 July 2017 at 3:28am
Hi I'm Currently Using Super Scoops Loaded With 21” RCF LF21N451 In A 3 Way System Setup Crossover At 90hz They Sounds Great I Love Them Very Much But Wood Worm Has Taken Them Over So I Have To Rebuild Was Wondering If There’s A Smaller Enclosure I Can Build That Would Give Same Or Similar Performance As The Super Scoops Are A Pain To Move Around With.
Let The Music Play
Crashpc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crashpc Quote  Post ReplyReply Direct Link To This Post Posted: 25 July 2017 at 4:08pm
Hey. I guess there is not much similar. Every enclosure type has its strenghts and weaknesses, and that´s why we build them all, dependin on ones needs.
I just got 21" in a bassreflex box, and it is unlike any 18" I´ve heard before. The bass is thick and sick. But it propably won´t hit that hard in the upper range. Only thing you can do is to find an inch smaller scoop :-D
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 July 2017 at 7:39am
mini/midi scoops if you like the sound of the big scooper…..
Rhino scoop with PD1850 for example can go flat down to 40 Hz (I've measured it), and has a nice punch.  "Some" builders are said to have even more potent mini designs. But then comes the perpetual question of how to get a DIY plan. Don't ask me, this is the scoop forum, no one is supposed to disclose anything y' know OuchEmbarrassedConfusedWackoLOL
cloak and dagger business seen?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 28 July 2017 at 9:55am
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 31 July 2017 at 3:30pm
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 31 July 2017 at 4:10pm
LOLLOLLOLLOLLOL
Edited by bob4 - 31 July 2017 at 4:11pm
midas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote midas Quote  Post ReplyReply Direct Link To This Post Posted: 19 November 2017 at 10:47am
Originally posted by Dub Specialist Sound Dub Specialist Sound wrote:
Who’s design are those bud?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 19 November 2017 at 10:35pm
Started out as the MS MK2 , but with own mods/tweaked internals,
over built a little, more bracing all double inside the horn path, rear double baffle id done this few years ago
cheers J
Post Options Post Options   Thanks (0) Thanks(0)   Quote midas Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2017 at 9:38am
Nice and tidy looking boxes.
