  New Posts New Posts RSS Feed - powersoft,ffa or mc2
abrupt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote abrupt Quote  Post ReplyReply Direct Link To This Post Topic: powersoft,ffa or mc2
    Posted: 04 August 2017 at 12:16am
what are the better of these amps,in respect of durability,repairability,and power consumption
compairing k10,e90,ffa 10,000
running sub from 23hz at 4r
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 04 August 2017 at 1:14am
K20
Edited by Sypa - 04 August 2017 at 1:15am
Post Options Post Options   Thanks (1) Thanks(1)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 04 August 2017 at 1:18am
Originally posted by Sypa Sypa wrote:
K20
jacethebase View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 04 August 2017 at 7:17am
Depends on your situation.
Powersoft K10 is the most powerful out of those 3 in real terms.
BUT..... If you are not doing shows where you have at least 32amp single phase supply to power the K10 with a decent feed then the FFA with its twin PSU wins hands down. As the amplifier can actually get its required power from 2 x 13a sockets.
Pasi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pasi Quote  Post ReplyReply Direct Link To This Post Posted: 04 August 2017 at 9:21am
One thing to note as well is the dual mono construction Jace mentioned and the extra security it gives. If for example one PSU fails, you can still use the other channel in that same amp. And since both channels have dual speakon sockets in them, you can just swap the cable over from the failed channel and go down to 2 ohm load for the rest of the gig.
If Powersoft blows its internal fuse, like they tend to do every now and then, you lose the amp.
Post Options Post Options   Thanks (0) Thanks(0)   Quote abrupt Quote  Post ReplyReply Direct Link To This Post Posted: 04 August 2017 at 9:23am
so the mc2 e90 isnt a good option
Hvedstrup View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hvedstrup Quote  Post ReplyReply Direct Link To This Post Posted: 04 August 2017 at 9:36am
Powersoft wins on sub among the mentioned. One of my K6 has 4500 hours on the timer and beeing driven hard for many of these. Besides that they sometimes loose the display when used near smokemachines they are very reliable.
For mids and highs there are better alternatives.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 04 August 2017 at 11:49am
If your main objective is 23 Hertz, it would be wise to rent all three and make a comparison. A lot of amplifiers begin to reduce their power as they approach 20 Hz which, many would not realise as they use HPF filters within the 30 – 40 Hz range.
Best Regards,
Post Options Post Options   Thanks (0) Thanks(0)   Quote abrupt Quote  Post ReplyReply Direct Link To This Post Posted: 04 August 2017 at 12:33pm
Best Regards,
not exactly just the subs i will be using can achieve that.i would expect to be using a hpf around 27hz
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 04 August 2017 at 1:04pm
The Powersoft has no problem delivering 20Hz
Pasi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pasi Quote  Post ReplyReply Direct Link To This Post Posted: 04 August 2017 at 5:55pm
Yes, just need to use bridged K20 to get some decent output ;)
Remember how APA had an octave more bottom end compared to your X4?
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 05 August 2017 at 6:30am
Remember how it also went into thermal protect?
No need to bridge them, plenty of juice for any box. Can buy two for the price of an APA too ;) and the software isn’t useless! Wins all round
