  New Posts New Posts RSS Feed - Best scoop for 18NLW9601?
djkeet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djkeet Quote  Post ReplyReply Direct Link To This Post Posted: 29 October 2017 at 1:04am
Originally posted by bee bee wrote:
ive loaded scoops with this driver and had GREAT RESULTS,
Do you remember which scoops Ben
I think it will be interesting to see the results of the RTA's do you have other scoops to AB against as well?
Soundbite
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 29 October 2017 at 11:40am
Those are not suitable for scoops.
To be clear...
Are you saying, 18sound 18NLW9601, are not suitable for Scoops !?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 29 October 2017 at 12:50pm
To be clear...
Those are your own words from like 4-5 years ago :-)
You made me stupid back then when i said it will kill in a right scoop.
Remember?
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 29 October 2017 at 1:07pm
To be clear...
Remember?
Maybe you'd like to present that post here?
EDIT: "If you didn't just make that up.. That is.."
Edited by levyte357- - 29 October 2017 at 1:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 29 October 2017 at 2:00pm
I ma not the only person that remembers this.
There is even your statement confirming this. But i have no time to bother and dig old topic. I have better things to do.
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 29 October 2017 at 10:44pm
correct, lol.... the 9601 is a killer in the right scoop. most of the us guys have been using the 9601 for years...
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 29 October 2017 at 10:45pm
ive used them in my own designs and recently modded some original s118's with shims to fit them...
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 29 October 2017 at 10:47pm
I'm only doing the tests for a client to see and hear for himself. the a/b with different drivers will be done in the same mini scoop. so far ive lined up a few drivers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 30 October 2017 at 2:00am
As I thought, making stuff up to cause another argument.
I may have said "expensive and not as sensitive as some", but that would be it.
Facepalm.
Motion54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Motion54 Quote  Post ReplyReply Direct Link To This Post Posted: 30 October 2017 at 9:46am
This driver sounds mental in my design.. (Lev .44)
Unfortunately, the design is not a free plan.
I have a set of four of these scoops available to buy. Haven’t got around to messing about with them as I still have 12 other scoops.
Post Options Post Options   Thanks (0) Thanks(0)   Quote djkeet Quote  Post ReplyReply Direct Link To This Post Posted: 30 October 2017 at 12:44pm
Yes because that would be a really tight fit
Soundbite
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 30 October 2017 at 11:41pm
correct they wont fit in a standard s118. the baffle cutout is too small, and due to the rebate for the original jbl drivers, the 9601 would hit the back baffle, so a shim is needed.
