Best scoop for 18NLW9601? |
Post Reply | Page <1234> |
Author | |||
djkeet
Do you remember which scoops Ben I think it will be interesting to see the results of the RTA's do you have other scoops to AB against as well? |
Soundbite
levyte357-
To be clear... Are you saying, 18sound 18NLW9601, are not suitable for Scoops !? |
MarjanM
Those are your own words from like 4-5 years ago :-) You made me stupid back then when i said it will kill in a right scoop. Remember?
levyte357-
Maybe you'd like to present that post here? EDIT: "If you didn't just make that up.. That is.." Edited by levyte357- - 29 October 2017 at 1:10pm |
MarjanM
I ma not the only person that remembers this.
There is even your statement confirming this. But i have no time to bother and dig old topic. I have better things to do.
bee
correct, lol.... the 9601 is a killer in the right scoop. most of the us guys have been using the 9601 for years...
bee
ive used them in my own designs and recently modded some original s118's with shims to fit them...
bee
I'm only doing the tests for a client to see and hear for himself. the a/b with different drivers will be done in the same mini scoop. so far ive lined up a few drivers.
levyte357-
As I thought, making stuff up to cause another argument. I may have said "expensive and not as sensitive as some", but that would be it. Facepalm. |
Motion54
Old Croc Joined: 13 November 2010 Location: London Status: Offline Points: 1753 |
I have a set of four of these scoops available to buy. Haven’t got around to messing about with them as I still have 12 other scoops. |
djkeet
Yes because that would be a really tight fit |
Soundbite
bee
correct they wont fit in a standard s118. the baffle cutout is too small, and due to the rebate for the original jbl drivers, the 9601 would hit the back baffle, so a shim is needed.
