Full 4sub 2MT 2horn Paraflex rig build kit |
Dokkodo ![]() Registered User ![]() ![]() Joined: 22 December 2021 Location: Bristol UK Status: Offline Points: 19 |
![]() ![]() ![]() ![]() ![]() Posted: 12 May 2023 at 9:55pm |
Howdy all Short version - I am selling a birch ply set of panels which are essentially a CNC cut kit for 4 dual type-O Cram subs, 2 dual 15 mid-tops and will consider including 2 x 2” B&C DE750 drivers with JBL 2380a horns. Everything you need to build the cabinets and horns for a pretty decent paraflex rig! Extended remix - Im a joiner and run a small sound system i have built. About a year ago I drew and had cut all the panels you need to build the above. It was just as the russian-ukraine war was starting and the prices for BB ply were about to go sky high, so i panicked and ordered all this! However the reality is I am very happy with my little system as events I cater to with it are generally only up to a few hundred people and it satisfies all my needs, I dont have the time or need for a system thrice the size. Ill be a little sad to let go of this particular dream and might be open to a collaboration to get it up and running, where I provide the materials and build, for someone who can provide the drivers and racks and most importantly, gigs. But that would need discussing and i am probably happier with the simplicity of selling it. I will consider taking on the building of the cabinets without further rights to the rig, but would have to charge my workshop day rate. In any case I will provide the drawings I used for the cut list and the panels are labeled so assembly should be possible by anyone with some tools and a good amount of patience. |
