full system help |
paddyd11
Registered User Joined: 13 March 2006 Status: Offline Points: 11 |
Posted: 14 March 2006 at 6:38am |
hi there im looking intobuilding some of these but need a bit of info, i will be using them with either ev mtl's or t18's for medium to large halls and small outdoor systems. will these added with the above subs lwork as a full range system or will i need other boxes also. do they need to be run 2, 3 or 4 way etc thanks for your help
Mark James
i could imagine maybey a 15" in between but im not too familier with the t18. how high does she go? the porns sound ok apparently down to 120/130hz so if she can get up to 130hz without problems then you should be ok. if not then something like a hd15 [well a few obviusly] inbetween to allow you cross at like 170hz bassicaly is the t18 a sub or a bass bin? |
Insomnia
Old Croc Joined: 06 September 2005 Status: Offline Points: 1721 |
hi, the T18's of Mtls will go up 120-130hz no probs |
