  New Posts New Posts RSS Feed - Funktion one res 3 replacement compression drivers
Shadrack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shadrack Quote  Post ReplyReply Direct Link To This Post Topic: Funktion one res 3 replacement compression drivers
    Posted: 19 March 2023 at 11:38am
Hello
I’m looking to replace the compression drivers in some Resolution 3s , I believe they are fane cd 150. Some say you can put the evo 6 comps in them which is a good upgrade. What is best to get?
The cd 150 seem to be discontinued
Edited by Shadrack - 19 March 2023 at 3:58pm
Marko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marko Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2023 at 5:32pm
You can replace with EVO6 only if you have Resolution 3 EVO model which was transiton from Res3 to Evo6.
Original Res3 has 1"  HF and  Res3EVO has 1,4" same as EVO6.
This page was generated in 0.984 seconds.
