Funktion one res 3 replacement compression drivers |
Shadrack ![]() Registered User ![]() Joined: 04 February 2017 Status: Offline Points: 45 |
![]() ![]() ![]() ![]() ![]() Posted: 19 March 2023 at 11:38am |
Hello
I’m looking to replace the compression drivers in some Resolution 3s , I believe they are fane cd 150. Some say you can put the evo 6 comps in them which is a good upgrade. What is best to get? The cd 150 seem to be discontinued
Edited by Shadrack - 19 March 2023 at 3:58pm |
Marko ![]() Registered User ![]() ![]() Joined: 28 January 2009 Location: Croatia Status: Offline Points: 273 |
You can replace with EVO6 only if you have Resolution 3 EVO model which was transiton from Res3 to Evo6.
Original Res3 has 1" HF and Res3EVO has 1,4" same as EVO6.
