G subs and double 12 inch |
Foca_Dacian
Registered User Joined: 05 February 2011 Location: Romania,Cluj Status: Offline Points: 118 |
Posted: 27 November 2015 at 9:14am |
Would G subs loaded with 18FH510 Faital Pro(3 inch VC) and double 12 inch tops loaded with 12PR310 Faital+HF144 comps would be ok most genres of music?
I've build Cubo but I did not like it (works ok for dnb,dubstep,reggae,not for house and other genres with fast punchy bass) but not really musical sounding for my taste. I also have build reflex 150 liter,tuned to 46 hz boxes.These sound good for house music,but are not that good with dnb and other genres with low bass(don't go low enough)but sound more musical. Would G subs( beeing tunned lower,but @ the same volume/speaker) with double 12 inch tops(outputing some of the upper bass)would be a good combo for an allround sound system?
krazyneil
Young Croc Joined: 06 December 2007 Location: Bolton ,lancs Status: Offline Points: 1206 |
yes is the short answer
twin 18 subs with twin 12 tops is a proven combination wich works well with all types of music and somthing most manufauters produce themselves you only have to look at the ohm trs 112/218 combo and see how well its regarded might be worth looking at the 18hp1010 as they are 4" vc and not much difference in price, id think the 510 would probably play a little higher but the 1010 would probably be better lower down,sim it and see what you think
Edited by krazyneil - 28 November 2015 at 10:44am |
GOD TOLD ME TO DO IT !!!!!
Foca_Dacian
I allready have 2 x HF144.2 x 12PR310 and 2 x 18FH510,I just need to buy 2 more of each excepting the comps.
I'll post some build pics of them. Also I have 12PR300+HF144+Beyma TD385 that I'll be using for monitoring. I'll not be using Beyma TD385 in the double 12,I'm thinking of LTH142 from Faital as well. Edited by Foca_Dacian - 02 December 2015 at 4:21pm |
krazyneil
the faital lth142 or 18sounds xt1464 would be my horn choice in your situtuation
