  New Posts New Posts RSS Feed - G3/PSM power distro
G3/PSM power distro
MARTYNJONHALL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MARTYNJONHALL Quote  Post ReplyReply Direct Link To This Post Topic: G3/PSM power distro
    Posted: 06 December 2021 at 2:46pm
I've got 4 g3 packs and 4 psm packs in a shallow rack and as you would guess it's like a rats nest in the back.
Is there any way to get a little power splitter for each set of 4 to clear all the psu's out of the way and just have 1 or 2 plugs dropping out of the back instead of 8!
Cheers guys
Martyn
Edited by MARTYNJONHALL - 06 December 2021 at 2:48pm
imageoven View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote imageoven Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2021 at 7:46pm
Are these radio mic receivers?
Are you looking for a low voltage supply with multiple outlets?
Peter Jan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peter Jan Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2021 at 7:48pm
I always use these kind of power supplies to power several Sennheiser/Shure receivers/IEM transmitters in a rack:
https://www.conrad.be/p/mean-well-lrs-75-12-acdc-inbouwnetvoeding-gesloten-6-a-72-w-12-vdc-1439450
Or the ones you can click on a DIN rail :
https://www.conrad.be/p/mean-well-dr-120-12-din-rail-netvoeding-12-vdc-10-a-120-w-1-x-1297347?WT.srch=1&gclid=EAIaIQobChMI3Z7LiPbP9AIVBoXVCh2ZrQTkEAYYByABEgJY-vD_BwE&gclsrc=aw.ds&insert=8J&t=1&tid=13894944235_122657379817_pla-301443522443_pla-1297347&utm_campaign=shopping-feed&utm_content=free-google-shopping-clicks&utm_medium=surfaces&utm_source=google&utm_term=1297347&vat=true
Way more reliable (never had one go bad in over 20 years of use) than the rubbish original adapters, that have the habit of going bad regularly.
Edited by Peter Jan - 06 December 2021 at 7:52pm
BJtheDJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BJtheDJ Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2021 at 9:24pm
The OP is in the UK, and regretfully the conrad.be site appears only to
support customers in the EU.
This https://www.amazon.co.uk/POWER-SUPPLY-OUTPUT-SW4618-POWERPAX/dp/B01186EIWA
or similar would most likely do the job.
It's a difficult choice, would you rather have:
A: A vegan son.
B: An OnlyFans daughter
jacethebase View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2021 at 10:00pm
I might have just the things!!!
Drop me a WhatsApp tomorrow and I’ll send you some pics
Jace 07766140461
