  New Posts New Posts RSS Feed - Gain Structure
Gain Structure
DMorison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 07 March 2022 at 11:30am
You said in the first post the amp was clipping earlier than you expected, this is one (basic) way to set your gain structure to minimise the chance of that happening.
Aymara View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aymara Quote  Post ReplyReply Direct Link To This Post Posted: 07 March 2022 at 1:08pm
Yes but how you turn down the output of a DCX?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 07 March 2022 at 1:28pm
Use the limiter. Available on each output channel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aymara Quote  Post ReplyReply Direct Link To This Post Posted: 07 March 2022 at 2:18pm
I don't get what you're saying... How do you turn down the output? Can you say it in different steps?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 07 March 2022 at 2:33pm
Sorry, I haven't used the DCX enough to know this immediately but it will be in the manual, look for it there Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 07 March 2022 at 3:32pm
The thing has a limiter on each O/P channel. You can use that to make sure that you don't clip your amps.
OR:- Yes, read the manual!   Smile
