  New Posts New Posts RSS Feed - Gap between boards in the corner of my sub
Piato75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Piato75 Quote  Post ReplyReply Direct Link To This Post Topic: Gap between boards in the corner of my sub
    Posted: 03 May 2023 at 11:48am
Hi,
I have an issue regarding some of my subs
Here is a video showing the problem : https://youtube.com/shorts/vbTRw0NVkl4
There is a small gap between boards above the screw, it can be seen in the video.
What is the best way to fix that ? Should I nail it with a nail gun ?
Is it bad or can it happen ? As the construction looks serious
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2023 at 1:00pm
it can happen. pour or brush a little pva or some other wood glue into the gap, and if you have a nail gun, use that, if you don't, drill and put a new screw in. will be fine.
snowflake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2023 at 1:31pm
doesn't matter too much where it is. tip it up and then get some glue in the gap so that it will run down to the end of the split. then clamp and put some more screws in.
maybe put a screw in to stop it spreading before you lever it apart to get glue in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Piato75 Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2023 at 1:52pm
Alright, I'll try that, thanks for your answer !
