Gear that substitutes a reggae preamp |
Post Reply | Page <1 23456> |
shagnasty
Thanks(1)
TBH I see more mono kit, the whole system becomes a VERY musical instrument at the hands of the crew, a good sound (as in sound guy) will blend a CD to 1 worn out 7" and back with a fluid motion, a Soundweb gives 8in>8out, you can build what ever programs you want (Comps, parametrics, Xovers, mutes, FX punch overs) and pul them to 8 controls, add a touchcreen laptop or iPad to the you 8 input suface can be anything, the 9000 unit go for nothing and add 8 more "control ins" (or you can build a 20 control surface and use RS-232) I look at what Pre's get used for and a Soundweb with a "creative" face and a "tech" LMS to interface the amps ticks so many boxes..... I agree, analogue is dead, to many compromises and no flexibility, people look at Reggae culture as backward, they are So wrong, Reggae stubbornness, brute force innovation and creativity has probably contributed more to current pro audio than can ever be believed, these guys were dropping low and singing sweet before any brand name of PA we use today had built it's first box..... The reason a good sound system can hold it's own is simply the bit between the Pre and the floor, tech wise you can tear many holes, but on the they deliver, every night... Wouldn't wanna hear them mix Van Halen, but would LOVE to hear them play Van Halen!!! Edited by shagnasty - 19 January 2016 at 2:42am |
app
Old Croc Joined: 26 December 2013 Location: Finland Status: Offline Points: 2435 |
As said before there must be a separate signal processor later in the chain. Still its a cheap way to get a thing that works in many ways like a reggae preamp by getting two mixers and a crossover. Trust me, I use one atleast monthy and theres no problems with it and it has cost me a lot less than a "real" reggae preamp. You can also do things with a mixer based pre you cant on a traditional reggae preamp. There are different ways of doing things... edit. And I dont use scoops edit2. Im afraid of digital mixers etc. I like limitations in a way,you sort of need to be more creative with limited resources. My resources (money) is very limited Edited by app - 19 January 2016 at 2:59am |
"what!?"
pdr
Registered User Joined: 05 January 2016 Location: UK Status: Offline Points: 91 |
"Don't bring a Navy Seal to an SAS fight" has to be one of the comments of the year so far.
Earplug
"3rd world country"?? Man - you are on drugs! Or cut back on that coffee and sugar - it´s warping your mind. Look at what my location says. And if you look at my previous post (or actually bother reading any of the posts before piling in), you´ll see that I linked to this: http://www.ebay.es/itm/Vintage-EQ-Altec-1905A-Klark-Teknik-5-Band-Parametric-Equalizer-/301844792482?rmvSB=true Is that enough of a parametric for you? Gotta love this forum. |
jammin75
Old Croc Joined: 08 July 2012 Location: west midlands Status: Offline Points: 2375 |
my scoops got passive crossovers in them |
shagnasty
My apologies, for some reason I thought your location read United States, my bad... |
Earplug
Ok, no problem. So you don´t like our US cousins then? I´m sure that they´re not all like Trump!
shagnasty
A few tours with them and you realize the reason they are only allowed half mains voltage!!!
darkmatter
In my opinion, you either go fully 'new skool' i.e. everything happens inside a computer and you have midi controllers doing the job of a pre-amp. This costs plenty and reliability could be a concern, but it also opens up a world of possibilities.
Or you get a proper preamp. The 'in between' options tend to overlook the fact a preamp should be played like an instrument, rather than left in the background as a system controller (LMS style). Anything in between I'd rather forget it altogether and stick to a normal DJ mixer > LMS setup. Just my personal view.
Edited by darkmatter - 20 January 2016 at 1:40pm |
paulus
Old Croc Joined: 14 December 2005 Location: SOUTH BIRMINGHA Status: Offline Points: 3181 |
i use a main mixer,then eq then lms, i feed the lms back into mixer and assign the bus outputs for the sub and kick and rest on mid highs, then my source i run threw a small mixer with kills on and effects also so can mute the mid top and leave the bass going and this only effects the source, added bonus is also got 2 separate send and returns , so i use extra Roland echo on this and can add effects on any channel needed, half the price of a pre,much more control and can eq each section,ajust x over points, and fully time align the whole sound ,running it 6 way mono all xlr connections and works very well with no reliability issues over last couple of years ,
Edited by paulus - 20 January 2016 at 3:03pm |
TRENDSETTER SOUND SYSTEM
app
A mixer was played like an instrument and it created a thing called dub. So "dissing" mixer based "ghetto pre" as an instrument vs preamp makes no sense Edited by app - 20 January 2016 at 8:17pm |
"what!?"
m0gsi
Registered User Joined: 09 February 2015 Status: Offline Points: 99 |
Rigsmith is making a parametric, filter and kill switch 1U stereo box for use with an LMS. Worth checking out as a budget option.
Edited by m0gsi - 20 January 2016 at 11:19pm |
