Gear that substitutes a reggae preamp |
Post Reply | Page <1 3456> |
shagnasty
Doing it inside a PC is near impossible without a face off Waves engine, even the best soundcard solutions (PCI-e or Firewire) offer latency that is not gonna cut it as a Pre, we have all heard the car crash that is Mainstage, you need a dedicated DSp minus the fluff of an OS, a BSS Soundweb would be Rock solid, is cheap second hand and is gig proven, you may also get away with a X32 Rack (cheap 22>14 DSP) and custom OSK layer to a midi panel in the X32 edit stylee, personally I would never use the outs of ANY digital Desk (SSL, Midas (Proper, NOT Behringer) Soundcraft (Vi, not jizz) or Digico, let alone teh other ones (Yes, Avid,Yamaha, Presonus) as an LMS, but if you must, an X32 is the cheapest and most control accessible option, but TBH for a Pre, all a bit too much.... List waht you want it to do, and look at what a Soundweb does.....
Edited by shagnasty - 21 January 2016 at 1:16am |
Roman
Registered User Joined: 01 April 2017 Location: New Zealand Status: Offline Points: 66 |
Seen, this is what I want to do with an Allen and Heath Mix Wizard 16 rack mountable mixer. I was thinking the crossover output could come into 4 channels and go directly out the direct outs. The modern Mix Wizards don't seem to have buses. Maybe get a tech to remove the stereo bus assignment buttons from those crossover channels to avoid accidentally causing feedback. Mix Wizards have 2 channels of built in effects which seems handy. Echo etc.
Roman
I plan on using a Mix Wizard. Seems more flexible than a reggae pre amp. Easily incorporate live horns and other instruments. Heaps of inputs (16). Can you explain your aggressive objection?
Roman
Can you be more specific. What would you miss out on with a Mix Wizard, crossover, filters for sweeps. The MW has advantages. Lots of inputs, built in effects, etc.
valve head777
Old Croc Joined: 27 July 2012 Location: East Sussex Status: Offline Points: 1781 |
Tbh, if you haven't got a pre, and never used one, you don't know what you are missing.... Borrow a pre, become familiar with it, and then recreate it using different outboard gear. Many have. Sometimes experience sorts the boys from the men....
dj jammin
Young Croc Joined: 10 April 2010 Location: southampton Status: Offline Points: 770 |
A mix wizard (from what i understand) is a mixer. A mixer is not a reggae preamp. To get the functionality of a preamp you will need other equipment and some way of wiring it all together. This is where a preamp excels.. it does everything you need in one box without all those wires.. the bit it doesn't do- the effects is ideal really as you can pick and choose and change the effects you want to use.
Have you ever tried using the built in effects of any mixer etc for sound system and had good results? I strongly doubt it.. Lots of inputs.. for what? Preamp has all the inputs you need.. if you need more plug a mixing desk into the preamp.. Like Valve said: if you haven't got a pre, and never used one, you don't know what you are missing.... |
Reverence Sound system
valve head777
Thanks(1)
Roman posted he produces music, so I assume he has knowledge of mixers, eq and send/returns etc. What should be realized is that the original concept of a pre was born within a studio, then neatly packaged into one handy box. Anyone with this knowledge should be able to reverse engineer a pre and come out with the functionality equaling a pre. App seems to have, as did I back in the day. Big up Reference Sound System....
Roman
I've got sound system associates that could let me experience hands on time with a professional reggae pre amp. Good idea. Maybe I will learn some of the quirks that makes these things so highly spoken of. I can't see too much mystery myself.
Shimad
Registered User Joined: 19 August 2014 Status: Offline Points: 16 |
At Reggaebus festival in Belgium last week, someone was promoting his software, designed to replace preamp..
BigSoundNorthWest
Registered User Joined: 29 November 2014 Location: Manchester Status: Offline Points: 290 |
JBK
Registered User Joined: 03 March 2016 Location: Besançon Status: Offline Points: 263 |
just saw this thread, most DAW's and modular synth platform can be transformed in a preamp. I've made a "mini" web pre few years ago (could/should expand to an equivalent of ampfreqq if I had the time :) ) Somebody has made a similar google chrome plugin (can't find it back now, though). Ampfreqq look great, but I find it a bit expensive for what it is (given that anyone can do the same with any audio modular system...) but eh it's a great and pretty complete solution for people that don't want to take the time to build something up. My dream would be to do a full software pre running on a computer, with a big audio interface for the in/outs and a custom midi controller. Put that in a preamp-looking box (with a small enough PC) and boom! you've killed it (yeah I'm a software dev) Nothing can touch that preamp feel though, with knobs and kill switches :)
BigSoundNorthWest
Google
"AmpFreqq".... software pre, 85 quid. then run thru a crossover... Edited by BigSoundNorthWest - 05 January 2020 at 4:35pm |
