  New Posts New Posts RSS Feed - Generic Fluids In Martin Smokers
SteveAATW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveAATW Quote  Post ReplyReply Direct Link To This Post Topic: Generic Fluids In Martin Smokers
    Posted: 26 January 2009 at 4:16pm
Anyone ever tried using the stairville/generic fog fluids in the martin machines?
H... View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote H... Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2009 at 5:25pm
Done it in antari machines - a regular clean with distilled water & a little pure white vinagar cleans the gunk out. No problems so far.
jonminns View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jonminns Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2009 at 7:45pm
It'll work, but zr mix is so much better than most of the stuff out there, the price difference is lost in all the extra fluid you'll use and the cloggage
Jon
Post Options Post Options   Thanks (0) Thanks(0)   Quote mk2_ginger_biscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2009 at 2:21pm
smoke fluid is just glycol (type of glycerine) watered down, roughly 30% water.
the cheaper ones use less pure glycol and often have other unfiltered crap left from the manufactoring process. this sticks to the insides of your machine and eventually blocks it.
also cheaper fluids generally dont distribute around the venue quite so well. i find the proper martin fluids actually dissipate and create a nicer even haze than the cheaper brands.
