Glued drivers :/ |
serioussound
Registered User Joined: 01 December 2013 Status: Offline Points: 443 |
Posted: 25 May 2019 at 8:51am |
Im into buying some new homebuilt midtop and subs loaded with nice older RCF drivers.
The thing is the drivers are glued to the cabs.... I can probably buy these cheap but is it even worth it since my thought is to rebuild these a bit. Anyone have experience with removing glued drivers?
Digbethdave
Registered User Joined: 16 November 2018 Status: Offline Points: 406 |
What kind of glue?
serioussound
I dont know actually not yet seen them in person.
Conanski
serioussound
Maybe the rebuild is no more than changing some woofer and put in some handles ...
I think maybe I kan cut through the glue with a dremel or a fein multimachine but its easy to maybe cut all the way into the cone ..? Anyone experienced glued woofers before? If to change the whole front baffle is there any standard way to do it?
