Grilles for X1? |
Post Reply | Page 123> |
VinceC
Registered User Joined: 19 December 2007 Location: Potters Bar Status: Offline Points: 64 |
Posted: 10 August 2012 at 12:32pm |
Hi All,
Having just discovered a Void V18-1000 paper cone has been munched by a mouse that got inside one of my X1 cabinets, I am thinking it might make a lot of sense to put grilles over the ports!!
Has anyone tried this?
I would like to set them inside the ports, but that would require a small wooden batten - maybe 3/4" wide - set inside each port to screw the grill down onto.
This will disrupt the airflow to an extent, and reduce the port area, but would it be a significant effect?
Any thoughts or ideas gratefully received.
Cheers, Vince
Your Music. Your Sound.
Wrek0ne
Young Croc Joined: 10 February 2011 Location: Cambridge Status: Offline Points: 749 |
A grill will not affect the sound in any way. Putting the grills on the inside is common on bp6 sub ports. Sorry to hear your cone was munched, never herd of it happening before but I could see why a mouse may find an X1 a desirable home.
Poll this!
VinceC
Hi Wrek0ne,
Yeah, it was a bit unexpected!! Here's a pic of the damage:
Thats no way for a V18-1000 to die!
Thanks for the advice - much appreciated. These X1s were installed in a venue for a while, and it seems the punters will put just about anything in any available opening. I also found a bottle cork, 20p and a serviette in this one!!
Cheers, Vince
markie
Old Croc Joined: 31 October 2005 Location: Sunny Liskeard. Status: Offline Points: 4570 |
I have loads of offcuts which would be suitable.
VinceC
Hi Markie,
Thanks for the offer. I still have some perforated steel in stock from previous re-grilling projects, but if I run short I'll be sure to contact you.
All the best,
Vince
cassiya
Young Croc Joined: 13 January 2013 Location: london Status: Offline Points: 626 |
Markie..
Why not just fit round 18" grills over the speaker? That way our void is protected and your Mouse still has a home..I think thats a very good compromise..
Just because you got more boxes that don't make you a man....
VinceC
Hi Cassiya,
Snag is the cabinet is a reflex design so the little blighters could still get in round the back if they fancied a tasty Void snack.
I've cut some grilles to put in the ports now, and I'll post a pic once the weather improves and I can wheel an X1 out into the light!!
Cheers, VInce
odc04r
If it's any consolation it looks like an easy repair, only needs the surround replaced.
VinceC
Its a recone job as you can't repair something like that - Void have the recone kits, I just need to get round to buying one!! |
V-ITAL Sound
Registered User Joined: 01 September 2009 Status: Offline Points: 189 |
anybody done this already?
put grills on the ports? I want to prevent people from kicking glass and other shit in. anybody have an idea how to solve this cheaply? thanks Edited by V-ITAL Sound - 02 April 2013 at 7:55pm |
VinceC
Hi,
Yes I have made some grilles, and I fitted out one cabinet before the winter closed in last year. I've got my other 3 X1s still to do, so I'll try to take some pics and put them up here soon. Basically, I cut perforated steel grilles that fit in the 4 port openings, and used a wooden batten at either end of the port to support the grill. As the grilles are pretty small, the two battens is enough to hold them in place with minimum impact on the port area. They will definitely keep junk and small furry creatures out!! Cheers, Vince
C-Audiofreak
Registered User Joined: 12 June 2014 Location: Norfolk uk Status: Offline Points: 467 |
i have spotted mouse shit in the storage room where i intend to keep my x1's megatons and ev tops would really liketo seesome pics of how people have added port grills to theirs if anybody has pics
