groove joints |
Daganjah
Registered User Joined: 29 June 2020 Status: Offline Points: 15 |
Posted: 08 July 2021 at 1:24pm |
hello everyone
i want to try using groove joints for my next build but I do not know how to calculate the depth of the groove that will give me the strongest. do you have tips for me? |
cravings
I've always done 5mm. In either 18mm or 15mm ply. It keeps the main piece thick enough, and it's deep enough for the dado to be effective. And it's easy to just add 10mm onto the relevant panels when working out your cuts.
I'm no expert though |
snowflake
strongest is probably half the board thickness, but that's a lot of sawdust and probably not possible to cut in one pass. and you would have to be careful your screws didn't go through the cut board. my router has 3mm steps on the depth gauge so I just use 3mm - it's enough to get things slotted together. 5mm/6mm also possible in one pass but more than that only if you have very sharp router bit.
Daganjah
thank you!
you helped me a lot |
Teunos
+1 on 5mm, main reason being that it creates a sufficient depth to be easy to work with if you bump the panel into it, leaving enough flesh on the other panel and being by far the easiest to work with in calculations.
Best regards,
Teun. |
smitske96
Young Croc Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1092 |
I also used 5mm in all previous files, works perfect for me.
fat_brstd
Old Croc Joined: 23 August 2008 Location: Melbourne, OZ Status: Offline Points: 2126 |
Another vote for 5mm here, makes calculating sheet sizes easy aw you just add 10mm to the width
Melbournes Rootical Warrior Roots - Dub - Steppers facebook page |
